BumblerBee
Flight distance : 639764 ft
Norway
I was flying the other day at sunset, and noticed at one point dark horizontal lines going up and down the frame. One would usually see such lines in artificial lighting when the frame rate does not agree with the power line rate, e.g. 50Hz. However, here I was filing in daylight.
In the attached image I increased the contrast to make them more noticeable, and placed two orange lines at the center of two of the more prominent lines.
Can it have something to do with facing the sun?
I had a DJI ND8 filter on. Camera was in PAL mode, 2.7K 25fps and 1/100 shutter speed.
I also got some Moire effect in the waves, and I don't know if it was because of the filter. I can also se camera ring reflection in the filter, which I should rememebr when flying with ND filters in the futue.
