Anyone having luck with 3.1.14? What tablet?
1013 6 2017-8-12
Inspector_Tim
Flight distance : 35899 ft
So.. there was an IOS update last week, 3.1.14 and *some* improvement..
I have an iPad mini 2.. and while it's a little better, the feed gets choppy after a minute or two.. and I still get the CPU overload message.
Is anyone having any luck with newer iPads? Android versions?
I don't want to buy/replace if issue persists with newer devices..
2017-8-12
RedHotPoker
Flight distance : 165105 ft
Which drone model are you specifically referring to here?
My Phantom 3 Pro, has been fine with the latest updates of firmware and the recently improved Go app.
My device of choice, has been awesome from day one. An iPad Air2 64gb Cellular. No cellular network installed.
RedHotPoker
2017-8-12
Inspector_Tim
RedHotPoker Posted at 2017-8-12 19:24
Yes, I should have mentioned. P3P iPad Mini 2.. w/latest update of DJI Go
2017-8-12
RedHotPoker
Inspector_Tim Posted at 2017-8-12 19:27
Ok, no biggie! Ha
You might try to uninstall the app, delete your internet cache and cookies, then reboot the device before you try a reinstall of the  "Power Hungry" Go app.
RedHotPoker
2017-8-12
DJI Diana
Flight distance : 2408 ft
And do not run other apps in the background when you are running the DJI GO 4 APP.
2017-8-12
Inspector_Tim
Thanks for replies, fresh reinstall of app, no apps running in background. As mentioned, the most recent update helped a little, but still laggy & choppy feed and up until last two updates, the iPad and all other components have worked like a charm.
2017-8-13
Peterx
Flight distance : 1499708 ft
The Go app 4 can not used with a P3 i think. But Diana is right. Do not start anything else if you are using the Go app.
2017-8-20
