Forced Landing and fly away
1482 9 2017-8-13
Frangu
Flight distance : 19849 ft
The drone started landing with out me telling it to at 40% battery, my battery warning is set to 15% DJI GO 4 only said LANDING and I was unable to cancel. at this point i was still conencted and was able to control it. seconds later the drone started flying away and at this point i was unable to control it any longer. Luckily i was flying low and the drone flew into a tree and i lost a propeller, if not this would of been my second spark lost due to issues with the spark.
http://www.phantomhelp.com/LogViewer/YJ8BVCHWTU20U11NFRPF/
crash
crash
propeller
propeller
2017-8-13
hallmark007
Flight distance : 10017858 ft
It seems your spark went into forced landing at 2.43 you can see on your log VPS altitude at 1ft were you flying over trees but close to them, because VPS shouldn't kick in unless something is close to underneath of the spark, if you were close to top of trees but Spark thought it was close to the ground just went into forced landing.
How ever it's something that shouldn't happen it is probably something you need dji to check out they can see a lot more from your dat file, so I would first sync your flight and try to contact a moderator to see if they can get engineer to look at your dat file.
2017-8-13
Frangu
hallmark007 Posted at 2017-8-13 15:52
I was flying below  the trees at this point never went higher than the trees today, I guess something was telling me not to.
2017-8-13
TMUSVI
Flight distance : 228891 ft
U.S. Virgin Islands
why does it say  ActiveTrack, you flying with phone?
2017-8-13
Frangu
TMUSVI Posted at 2017-8-13 16:09
This was being flown with the RC. At some point I was trying to do active track.
2017-8-13
Kyokushin
Flight distance : 296381 ft
Poland
DJI go is sometimes stuck with refreshing battery level. It is shouwint 40% and you have 15%.
We need to look at the copter - all red lights means low battery.
2017-8-13
DJI Diana
Flight distance : 2408 ft
Sorry to hear about the crash, have you checked the drone, is it damaged? Please refer to the video below to export the data, then upload them to the Dropbox, post a link here. I'd like to forward it to our engineers for analysis.
2017-8-13
Frangu
DJI Diana Posted at 2017-8-13 18:10
Sorry to hear about the crash, have you checked the drone, is it damaged? Please refer to the video below to export the data, then upload them to the Dropbox, post a link here. I'd like to forward it to our engineers for analysis. DJI Quick Tips - Spark - Exporting the Flight Data
https://www.dropbox.com/sh/nhzku ... dK6bCpczaDFTza?dl=0
CAS-892583-X2J9L6
2017-8-14
LouisP
Flight distance : 41952 ft
Good to know about flying over trees.  The other day I was flying INSIDE of some trees, between the branches.. Would not want spark to try to land because it thought a branch was the ground.
2017-8-14
DJI Diana
Frangu Posted at 2017-8-14 07:14
Thank you for the info. I've added the data to this case, we'll  take care of the drone and submit a data analysis after it arrives.
2017-8-14
