Vik
So i purcahsed a used drone from a exchange shop here in the UK. It was listed as A grade which generally means almost new with very little wear on the item.
The Drone arrvied yesterday and the first thing i did was to charge the battery, when i plugged the charger in straight away i noticed that when charging the battery the led lights will cycle through but LED 3 was not lit up. I left the battery to charge fully to see what happened as i had to pop out for a hour anyway.
after about a hour the battery lights were off when i got home, so i did the test by pressing the power button for 5 seconds but only 3 of the 4 LED turned solid green with LED no3 not lightining up at all.
Does this mean the battery is faulty? I am planning to return the drone back to the supplier probably tomorrow once i get a email confirmation from them.
I am attaching photo of the battery.
I tried to google this issue but could not find anything hence my post here.
Thanks for your help...
