custom rtmp live streaming
19329 7 2017-8-15
srinathsam
India
Iam working custom app also bought mavic pro drone recently ,please suggest me how to broadcast live stream from drone to rtmp media server. How to convert input stream and flush into rtmp socket
2017-8-15
Nazar78
Flight distance : 5106037 ft
Singapore
See here, good stuffs: https://forum.dji.com/forum.php? ... amp;fromuid=1006609
2017-8-15
DJI Susan
Please consider 2# suggestion and have a try.
2017-8-19
Tege
Flight distance : 119091 ft
Finland
Is twitch support coming?
2017-8-20
JinxTheRabbit
If you have Docker installed, you can simply run
docker run -d -p 1935:1935 --name nginx-rtmp tiangolo/nginx-rtmp
You can find more information on that container here: https://github.com/tiangolo/nginx-rtmp-docker
Then in DJI GO 4, use rtmp://<ip address>/live
Be sure to substitute the IP address of your computer running docker for <ip address>.
To view, you can open VLC and go to Media->Open Network Stream... and enter rtmp://<ip address>/live
It is that easy.
2017-12-29
ROCC
Flight distance : 18445 ft
Jordan
JinxTheRabbit Posted at 2017-12-29 13:03
Hi,
Im using wowza as my server. When streaming to custom RTMP, the video is so jerky.
I think the issue is from that app. I have the remote with screen attached. Is there any guides that you can give me to have better view quality?
2018-3-14
Martin Fossland
Norway
Hi, I had success with this one the first time after installation :-)
Then I restarted my computer, and the Ubuntu Terminal responds with this: "The container name "/nginx-rtmp" is already in use" when I typed the command-line you wrote.
Is there another command to restart the rtmp-container after first time installation?
2018-7-24
Jimis.M
Flight distance : 754705 ft
Greece
Martin Fossland Posted at 2018-7-24 13:25
It means that is already running but if you want to run again just give a different name after --name --name nginx-rtmp
Try to run something like that:
docker run -d -p 1935:1935 --name nginx-rtmp2 tiangolo/nginx-rtmp
2018-9-30
