blackcrusader
Flight distance : 689774 ft
Taiwan
fans5f01fa88 Posted at 2017-8-18 21:33
So with a record cut off at 390ft up, everytbing aftet that is an assumption because we really dont know? I mean for all we know, all 4 props could have flown off right?
From 5800 feet away the Drone would not make it back to home point with the remaining power. That is not hard to understand is it? For all you know a bird strike a lost prop or a complete power failure occured. Maybe all three, a bird struck your drone, a prop came off sending your drone into a spin which ejected the battery. You have can have all three if you want. Main thing is you need to accept your drone did not have enough power to return home from 5800 feet.
RTH usually has a slow speed so from distance if you go to RTH then use full throttle to get home. This is what saved my drone when I had critical low battery, I was at max height so descending was at full left stick down, and as had a tail wind full throttle. my power levels were back to normal as the drone got back to home point as it effectively "rested" enough for power consumption to be reduced. I will still take another look at google earth and go and try to find your done, as recovery would give more data to analysis.
You current flight log shows you did not have enough power to get back in RTH from 5800 plus feet away the distance was too great. So your drone would have gone to critical low battery and auto landed. |
