H4-3D range
1184 2 2015-3-28
GrinderA10
can anyone help me with info on the range of the tilt feature on the Zenmuse H4-3D gimbal?
i only seem to get a slight tilt downward, approx. 50 degrees when using the tilt wheel?
shouldnt i get a full 90 degree tilt downward? as in looking directly downward.
and when flying horizontally does this gimbal tilt downward at all times?
2015-3-28
Eirlink
you need to go into the assistant and select new type transmitter as your option then calibrate the tilt
2015-3-29
GrinderA10
Eirlink Posted at 2015-3-29 22:08
you need to go into the assistant and select new type transmitter as your option then calibrate the  ...
thank you found it,
2015-3-30
