[SOLVED] Return-to-Home altitude changes mysteriously
1602 8 2017-8-22
MARSAN
Flight distance : 966978 ft
Belgium
I have set my Return-to-Home altitude to 40 meters in DJI GO 4, but mysteriously this value is changed to 20 m every now and then - no, not by me!
I suspect that one or more modes of the Intelligent Flight Modes is causing this error.
Yesterday afternoon at one moment I had been flying the Mavic in Point-of-Interest mode and later switched to normal P-Mode.
At one point the low battery procedure set in with automatic RTH and the Mavic was then still in P-Mode.
To my horror I realized that the Mavic did not rise to 40 m, but only to 20 m and on its flight home it just narrowly missed a tree.
I checked the RTH altitude in DJI GO 4 and it was indeed set to 20m!
What could be causing this mysterious modification to my preset RTH altitude?
Yet another remaining bug in DJI GO 4 or what?
DJI GO 4 version used is 4.1.5. and firmware is .0900.
Anyway, this is one more item I have to add to my pre-flight checklist or possibly even to my in-flight checklist...
2017-8-22
Nazar78
Flight distance : 5106037 ft
Singapore
I recalled seeing this too once, same Android app 4.1.5 same .900 firmware . Not sure how was I flying in between fly modes but manual RTH doesn't accent to the preset 50m altitude (confirmed in the app again it's 50m). Since the path is clear I just let it be think it was 20-30m.
2017-8-22
MARSAN
Belgium
Nazar78 Posted at 2017-8-22 01:27
It's not the first time that this problem occurred, but when it happens, RTH altitude is always 20 m in my case, the smallest value of RTH altitude available in the DJI GO 4 app.
If you have a similar problem, could you please check at what moment this occurs?
2017-8-22
Griffith
Flight distance : 98537 ft
Do  you fly above 20 meters?
2017-8-22
MARSAN
Belgium
Griffith Posted at 2017-8-22 04:55
I made a big mistake.
Blame it on age, teeny weeny print in POI and weaker eyesight.
I'll ask the moderators to delete this thread!
2017-8-22
Sportbike_Pilot
Flight distance : 10278435 ft
MARSAN Posted at 2017-8-22 07:20
  understand.
2017-8-22
MARSAN
Belgium
Go ahead and laugh, you are also getting older!
2017-8-22
Sportbike_Pilot
MARSAN Posted at 2017-8-22 09:39
So true b/c I need my glasses myself when I fly.....damn letters on screen are too small.
{:4_157:}
2017-8-22
MARSAN
Belgium
Sportbike_Pilot Posted at 2017-8-22 10:17
{:4_157:}
Aha!
Then please take a look at the tiny print on the POI page, where it says Return-to-Home altitude, because that is where I went wrong.
I had difficulties reading those tiny tiny tiny letters,
2017-8-22
