GSP -DJI Ground Station Pro
12Next >
12080 44 2017-8-22
Mari
Flight distance : 1308780 ft
Yesterday I stumbled upon the app called GSP (DJI Ground Station Pro)... viewed some videos about this app on Youtube, now I have some questions and hope someone can answer them.
- Is it safe to use this app?
- What about flight restrictions, height and distance restrictions are removed with DJI Go 4 when signed in, does GSP restrict the Mavic?
- What about flight-records?
2017-8-22
Ferks
I've used the app a couple of times with no issues, however I don't believe DJI even supports it even though it's their software, I believe it's because GS Pro does not create flight records, I believe GS Pro looks at the DJI Go 4 settings and uses them, not 100% sure on the last one.
2017-8-22
DJI Thor
Flight distance : 13602 ft
For the flight safety, flight environment matters a lot. For the flight restriction, you have to power on and connect the drone RC and DJI GO 4 app first and then launch GS Pro, or the drone will be limited at the moment. And this app doesn't generate flight records, but it will produce the flight data on the drone.
2017-8-22
Silmansbear
Flight distance : 376375 ft
Denmark
Do anyone know why i cant find the GSP in appstore? Im located in Denmark
2017-8-23
Ex Machina
Flight distance : 1806362 ft
Silmansbear Posted at 2017-8-23 11:52
Seems still in the store: https://itunes.apple.com/app/dji-gs-pro/id1183717144?mt=8
2017-8-23
Ex Machina
Ferks Posted at 2017-8-22 11:41
Looks like it was updated this month with several in-app purchase options and enhancements:
What's New in Version 1.6.0
1. New: Support for M200/P4A
2. New: Support for KML/SHP/KMZ file import, view, and creating flight missions accordingly
3. New: Save the current mission’s parameter as Default, so that newly created mission will follow the same parameter
4. New: Support Poly No Fly Zone
5. New: Add option to always display WGS84 coordinates, even in non-WGS84 environment
6. Enhancement: Max Flight Height extend to 500M
7. Enhancement: Flight Speed now could set down to 1 m/s
8. Enhancement: More information in the parameter info panel.
9. Enhancement: When setting camera pitch in 3DMap, the flight route will shift accordingly to capture the target area
10. Fix: No video streaming when using Zenmuse Z3 camera
2017-8-23
Ferks
Ex Machina Posted at 2017-8-23 12:11
Looks like it was updated this month with several in-app purchase options and enhancments:
Cool !
Have to get the update.
2017-8-23
ro_flyer
Flight distance : 7557283 ft
Brazil
It is only for IOS and iPad users
2017-8-23
Mari
Did fly with GSP yesterday... made a movie but forgot to focus... will give it another try {:4_181:}
GSP does overwrite some of the settings I made in DJI Go 4:  max. height, max. distance etc. So if you use GSP and later on use DJI Go 4 again you have to check you settings...
2017-8-23
Mari
Flight Altitude: 50mtrs
2017-8-24
Ex Machina
Mari Posted at 2017-8-23 20:17
Thanks, that's good to know.
2017-8-24
Mari
Today I tried to fly the mission again, was able to take-off but MP kept hoovering on the spot... didn't fly the mission...
Flew 3 batteries with DJI Go 4 app without any problems... have to check next time why I wasn't able to fly the mission...
2017-8-27
Ex Machina
Mari Posted at 2017-8-27 11:22
Using the latest firmware? Maybe the app needs to be updated for compatibility.
I upgraded and then I tried to fly a Hangar 360 mission yesterday and the AC did the same thing -- now, I didn't launch the mission from the ground but instead a few feet above after switching from DJI Go 4, so that may have confused the app, though I've done that before without issue.  After I manually flew it up to 300ft the app started working.
2017-8-27
Mari
I have updated to latest firmware in 22-08, flew the mission dit GSP on 24-08... so I don't think it has something to do with that...
2017-8-27
Mari
I deleted the second mission, made a copy of the first mission...
Made some changed (deleted in between points) lowered the gimbal 15 degrees and made curved corners...
Was able to fly the new mission without any problem.
I'm sure that I will use GSP more in the future...
2017-9-1
DocAraxá
Flight distance : 202283 ft
Brazil
This app is not suitable for me as I fly with a iPhone.
2017-9-1
Mari
... yes you need a bigger screen then the one of a phone even on an iPad 4 mini it is not easy to change some setting (DJI has to work on some things).
Just flew a mission of more than 2500mtrs.
2017-9-2
Mari
Would be nice if in the near future DJI will update this app and make it possible to "enter" a number instead of using sliders or + and - buttons... Sliders are to sensitive, using + and - buttons take much to long...
2017-9-2
Silmansbear
Denmark
Ex Machina Posted at 2017-8-23 11:53
Thanks, i tryed to find it on my iphone, but understand know, that its only fore ipad
2017-9-7
Mari
Yup, unfortunately it is only for iPad... DJI should develop GSPro for more devices...
2017-9-7
Ex Machina
You know, I've since had a couple more experiences with Hangar 360 hovering -- I'm pretty sure it's because I was in Sports Mode both times, and I keep forgetting that Hangar 360 -- and maybe also GSP? -- require the system to be in regular mode instead. Do you think you might also have been in Sports Mode when the hovering happened to you?
2017-9-7
Mari
Nope, I'm absolutely sure it wasn't in Sports Mode...
2017-9-7
Mari
Still struggling with GSPro... one of the options I can't get to work is "waypoint action". It says "n/a" and don't know how to change that
2017-9-8
FatherXmas
Flight distance : 4058619 ft
I tried it this afternoon. It still doesn't sync the flight records.
2017-9-8
Mari
GSPro doesn't create flightrecord only flight data like DJI Thor said in post 3 of this thread...
2017-9-9
Mari
Mari Posted at 2017-9-8 12:06
Does someone have any idea how to get "waypoint action" to work?
2017-9-21
Mari
Still no answer how to get the "waypoint action" to work... Maybe one of the moderators can ask the GS Pro tech-department?
2017-10-24
ro_flyer
Brazil
It's available in the Appstore for iPad only...
2017-10-25
Keule
Flight distance : 3733015 ft
Mari Posted at 2017-9-21 10:02
In GS Pro, create a Waypoint Mission,
then select a Waypoint (waypoint color = blue)
On the right side in your mission parameter panel select 'Each point'
Go down to 'Waypoint action' click on the > and the panel moves to the left, bringing up
the 'Add Waypoints Actions' dialog
Touch 'Add Waypoint Actions' then a list of actions appear.
Hover, Photo Capture, Start Recording, Stop Recording, Aircraft rotation, Gimbal Pitch Rotation.
Select your action.
Continue until you are finished with that waypoint.
Proceed to next waypoint.
I hope that helps.
K.
2017-10-25
Mari
... pressing ">" doesn't move the panel to the left... therefore I'm stuck there... must be something simple I'm overlooking...
2017-10-25
ctoms2
Flight distance : 2353743 ft
It is not just you. I am using an iPad Mini as well and am not able to use waypoint action.
2017-12-21
ctoms2
I think it is just some glitch not letting the options window open. The option window opens for the End Mission options if you select "All Points" and I imaging it is the same type of options window. I wonder if it works fine on a larger iPad?
2017-12-21
Keule
ctoms2 Posted at 2017-12-21 09:17
I made a quick tutorial with my iPad mini 4:
2017-12-21
Mari
Nice tutorial, but I'm not able to open "Waypoint Action" menu... I can press it many times, nothing happens... Viewed your tutorial many times... still confused how to open that menu!
2017-12-22
Mari
2017-12-22
Mari
I solved the problem... Removed and re-installed the app... Now I'm able to open the Waypoint Action menu... seems that sometimes its better to remove and re-install then updating an app...
2017-12-22
Keule
Mari Posted at 2017-12-22 01:33
Glad to hear you got it sorted.
To Uninstall / Install a DJI app is more and more getting a common problem solver.
2017-12-22
Jos A
Flight distance : 73209 ft
Alternative is Litchi and better!, for android and IOS
2017-12-22
Mari
...I don't give up that easy...  I started this topic because I think GS Pro is a nice app with potential and I'm sure I'm not the only one who is using it and may have problems with it.
Now DJI developers can read about the things we stumble upon, fix them and make this app better... and don't forget, this app is for free!
2017-12-22
fans27d6da55
Does anyone know of an app that works like GSP that is available to use on an iPhone 6+ for mavic platinum
2018-1-12
12Next >
