Error altitude and distance limited after DJI GO update to 4.1.7
3947 17 2017-8-27
Andicot
Flight distance : 1137044 ft
My Mavic has firmware 0700, the DJI GO is auto updated to 4.1.7.
Now at each motor start i receive this error: Your flight altitude and distance have benn limited to 30m and 50m.
Despite the warning I tried to take off and I saw that the Mavic can fly without limitation.
2017-8-27
Ribeiro
Flight distance : 2950994 ft
Brazil
I posted the same problem yesterday, but I am on 0.400. Flew as far as 2km and 120 m in altitude. But it always shows the message. It is either a bug or a mandatory firmware upgrade coming up for the Mavic.
2017-8-27
Pruddas.finest
Flight distance : 126401 ft
Ribeiro Posted at 2017-8-27 07:15
I've got the same, tried uninstalling and reinstalling the app, signing in and out, switching the phone off and on and it still remains.
My iPad is fine but I've not updated the app and don't intend to!
2017-8-27
Ribeiro
Brazil
I did all that multiple times, including changing my password. If there was a restriction it would probably point to a log in problem, but since I can fly beyond the restrictions it is probably a bug or something worse on the horizon. I think I will try to downgrade dji go to 4.15 and see what happens, but only tomorrow I will have access to a pc.
2017-8-27
adamob
Flight distance : 131562 ft
Russia
Same problem on 4.1.7  and 700 firmware
2017-8-27
dronist
People please read the info about each update before you decide to update. If it is NOT life threatening...
DO NOT UPDATE!
Also set your phone/tablet to NOT do automatic updates!
2017-8-27
Yokota85
Flight distance : 255430 ft
I am having the same issue but I did not upgrade it just started  with the error
2017-8-27
Ribeiro
Brazil
Lesson learned, do not upgrade dji go
2017-8-28
DJI Thor
Flight distance : 13602 ft
The app is on the latest version, this message might pop up since your aircraft's firmware is a very previous version and the login info doesn't write into the main controller correctly, but it might not really restrict the drone because of that old firmware reason.
We always suggest that users update both the firmware of the drone and app to the latest update because that will be the optimization for the previous version. Thanks for your kind understanding.
2017-8-28
Andicot
In the last firmware the bug of the preview of DNG file in MACOS Sierra is solved?
2017-8-28
Mari
Flight distance : 1308780 ft
Try and find out....
2017-8-28
Andicot
I bought a drone to fly ... not to do experiments and burn it in the firmware update or downgrade to avoid bugs...
2017-8-28
Damo0852
Exactly the same error. But it does let me fly beyond this distance etc. Still a little worrying. I'm on firmware 4.0 and latest dji go app. Hopefully they will remove the warning for those who do not want to upgrade
2017-8-28
Ribeiro
Brazil
After jumping through about a dozen loops I downgraded DJI Go to 4.13; but all my batteries are out of juice so I will test tomorrow.
2017-8-28
fansb1930b00
Flight distance : 444035 ft
I found a video on YouTube (Chad RC) he says to log out of DJI and log back in with the drone connected to DJI Go 4.  He said that makes the message go away.
2017-8-28
sven.pdtintl
I had the same issue with my Spark, it is a DJI bug.  After lots of searching and expirimentation i found my issue resided with the firmware update of the batteries.  In my case only the inital battery that was in my Spark updated correctly., with this battery the distance and height limitations were not there, but when i switched to any of my three other batterys that were subsequently updated the drone flight was restricted,   What worked for me was to install each of the  batteries into the drone with it powered up and sign out and back into my DJI account.  I had to do this with each battery but it resolved the issue for me when all elses failed.   Hope this helps.
2017-8-31
Andicot
I see update of DJI Go to version 4.1.9. With this version the problem is solved or remains? Someone has news?
2017-9-1
Bodgerator
Flight distance : 17943 ft
Same issue. Also being discussed on this thread in DJI Forums: DJI Forum Link
2017-9-9
