Spark sudden power cut!Dropped from 100M height
3339 21 2017-8-30
fans1b799873
Flight distance : 7802 ft
I have to report a severe inccident. 2 weeks ago, My Spark was taken off with full battery besides a beach, it suddenly dropped from 100M height. Fortunately, there were only a few people, no one was hurt. You can imagine how severe the inccident is!
After so-called investigation by DJI tech department, they said the flight record ended at that point, so the reason is unknown. They asked me to buy a new one with 30% discount. Is it the way to handle such severe inccident?You know it can put us in court if there is anyone hurt or killed!!
2017-8-30
Bobesh
Flight distance : 270840 ft
Czechia
Hey,
I had the same situation, but I was handling it on multiple places; starting with this forum. Forum moderators/admins are super nice and will help you with everything.
Long story short: After negotiating with support and on forums, I sent my drone to them, they said it was not a pilot error and repair/replacement was free. The drone is on its way to me as we speak.
See the thread here: https://forum.dji.com/thread-108591-1-1.html
I suggest starting a thread here on forum + support ticket. Online support is not going to help you in most of the cases, and if you have the forum thread, moderators are usually way faster to reply than support.
Cheers!
2017-8-30
Bobesh
Czechia
I suppose latest firmware was not available at the time of fall right?
2017-8-30
DJI Diana
Flight distance : 2408 ft
Sorry for the crash, did you find the drone?  If yes, did you send it in? Please provide me with your case number so I can look into it.
2017-8-31
fans1b799873
My case number is CAS-918842-N4M5C8. The drone dropped into the sea, no far from the beach. I sent all flight data and films to support team. Please help!
2017-8-31
PascalG
Flight distance : 274327 ft
I had a similar issue, drone disconnected 2000' away, never returned home and wasn't found. AftIer 2 weeks, DJI tech came to the same BS conclusion... flight record ended without any error, we ll send you a 30% coupon.  Not acceptable in light of the mandatory firmware update which came out a few days late but I guess all I can do is give spark another chance. Maybe the new FW fixed the problem.
I was tempted to upgrade to a Mavic but I still ont feel like risking $1000 every time I want to use it... plus it's heavier and could do more damage.
2017-8-31
InkedUpDad.com
Flight distance : 55276 ft
First off, I'm sorry to hear of your bad experience. It's what many of us and drone owners worry about. Now, to play devil's advocate. DJI and many agencies specifically advise against operating any drone near people. Even the best drones experience fly-aways, malfunctions and operator areas. It's best to always operate away from people and animals.
2017-8-31
Oracle Miata
Flight distance : 3759829 ft
Also sorry, but also agree.  Keep away from people and animals.  Again sorry for your loss.
2017-8-31
Jestered
Flight distance : 16112 ft
Not sure what the last couple of responses have to do with the OPs problem.  If they were asking for help from DJI because they injured someone, then yes, those responses would be valid.  That's not the case here though.  It doesn't matter if anyone was around or not.  It would not have prevented the Spark from apparently losing power and dropping into the sea.
I def think DJI should be replacing your Spark under warranty.  Good luck!
2017-8-31
PascalG
I don't fly near people but when these things decide to fly away or drop out you can't know where they're going to end up.
2017-8-31
Montfrooij
Flight distance : 2560453 ft
DJI Diana Posted at 2017-8-31 01:17
Please provide case number to DJI here.
Usually they can help.
2017-8-31
fans1b799873
Thanks all for your advice and support. We all know drone is dangerous if it is not operated properly. We do try to stay away from the crowds when it takes off. However, if it suddenly loses power during flight, it is obviously not an operator problem, right?
Once again, my case number is CAS-918842-N4M5C8. DJI please look into it and give a reasonable response. Also for all who have encountered similar problem, we need to fight for our right.
2017-8-31
Onomarn
Flight distance : 4728 ft
Same thing happen to me. My spark was lost at sea, DJI offered me the coupon and as this is a known issue DJI still refuses to replace my drone. I was eventually stuck in a tight place either buy the drone at a discount or lose everything all together. It sucks, I hope DJI fixed this issue with their new firmware release. Their approach to this entire situation was some of the worst customer service I've seen ever. I would advice against buying anything from them until they hire someone to handle their Customer service department better. BTW I did everything from calling, emailing, and chatting with online technical support. Tried the forums.
Good luck with your case, search these forums there are many others like us.
2017-8-31
fans1b799873
It is ridiculous!We have to fight for our right all together.
2017-8-31
DJI Elektra
fans1b799873 Posted at 2017-8-31 01:52
Since you provided your flight data to support, they would help you analyze the data and find out the problems. Please wait patiently.
2017-9-1
DJI Elektra
fans1b799873 Posted at 2017-8-31 06:58
Be aware that our support had sent you email about the solution today. And they confirmed that it was not caused by user and recommended replace it for free. Thanks for support.
2017-9-1
fans1b799873
Finally, DJI agrees to replace a new drone for me. I am appreciated they reconsider my case after I sent them an appeal mail stating all points mentioned above.
I hope they can fix all potentially dangerous issues such as power cut and flyaway as soon as possible.
Thanks all again.
2017-9-1
PascalG
I m glad that dji is offering you  a free replacement in your case as they only offered me a 30% coupon even though the cases seem very similar
This is tech support explanation for my  lost spark
For your claimed case CAS-923424-R2B0D0, we have already finished the analysis, and the result is as follows:
1. The aircraft worked in GPS mode, and responded to pilot's control well;
2. The pilot was pushing throttle stick upward(97%), then at flight time 02:38, H=81 m, D=579.2 m, the flight record ended;
3. The home point : 24.2615063 -76.5133729; the last point: 24.2657238 -76.5167435.
With the record ended without any sign of abnormality, we could not verify what happened afterwards.
Obviously if the droen shuts down, and disapears, there won't be any further entry. I wonder why your log showed anything different
I have accepted th 30%, no choice, but not sure if if will just use the park or sell it right away and get something else
2017-9-1
fans11bc4e17
Flight distance : 435873 ft
Uruguay
Hi there!! So strange behavior of the spark. This happened to you with the latest firmware?  V 01.00.0600 ??? Thanks
2017-9-1
fans1b799873
PascalG Posted at 2017-9-1 04:17
For all sudden power loss cases, the flight log is probably similar. Sudden flight log ended without any abnormality before that point, and they cannot figure out the reason. Only in cases that there is a second camera following the drone and recording what is happenings. But it is not realistic.
DJI should find a way to idenify this situation, otherwise, this will happen again leaving us hopeless.
2017-9-1
PascalG
That was before the firmware came out, about 3 weeks ago. I hope the new firmware will make it more reliable. It's a very nice drone but reliability needs to be improved
2017-9-1
DJI Thor
Flight distance : 13602 ft
fans1b799873 Posted at 2017-9-1 04:06
Thanks for your feedback, we will also report this case to our engineers to confirm, sorry again for this fly away case. Hope you will get your drone back soon.
2017-9-2
