P3S RC Mods
1921 20 2018-1-17
sSkyPilot
Flight distance : 311089 ft
Hi, I wanted to share my range extenders and device holder Mods I finished the other day. Both were and simple install by taking my time and following video instructions. It's has the look of a tricked-out contraption with the tablet. Hope she works. I'am waiting for warmer temperatures to test. I haven't read about any controller update I need with the range extender. Wonder if I need that now.
2018-1-17
AlanHd
Flight distance : 797365 ft
Let us know how it performs, did you do some baseline tests before the mod.
2018-1-17
sSkyPilot
I did a continuity test...
2018-1-17
sSkyPilot
Hmmm... baseline tests?
2018-1-17
ALABAMA
Flight distance : 10442687 ft
Did you have any trouble getting all the glue off the connectors?
2018-1-17
sSkyPilot
No... it's silicone... small dab on sides connections. I did make a mistake by using a hard tool, they recommend non hard tools. I did minor mares. I used hot glue dabs to secure. My wire lengths didn't match video's lengths. There lengths matched the socket... Mine were more long. I just matched wire color to socket mentioned in video's... Easy...  It is a task removing the silicon carefully. But it does come off. Use hard plastic tools.
2018-1-17
TruGreen
Flight distance : 621909 ft
i did the tablet holder upgrade as well but used a inset nut to screw the part into. How is yours held in place to not wobble?
2018-1-17
sSkyPilot
HI, I can't recall the size of the hole after centering the bracket. But after drilling... The bracket screw is self tapping, work careful turning. Over do it, it's stripped. just get the bracket threads seated.  I secured the inside shell/bracket with epoxy. I may put a dot of cyanoacrylate on the outside threads. But it's solid now.
2018-1-17
AlanHd
sSkyPilot Posted at 2018-1-17 14:47
Sorry I meant baseline range tests to compare against the new set up.
2018-1-17
TruGreen
sSkyPilot Posted at 2018-1-17 19:19
yea I followed this CLICK HERE and is nice and snug no wobble
2018-1-18
sSkyPilot
Hi, I watched that video TruG. Mine is also solid as a rock. AlanHD... I won't know a difference till spring... It's a winter kinda upgrade here. Winter brakes here in April or May. Always snowy,windy and freezing here. I liked the claims and feedback from users. So had to have it.
2018-1-18
fans46521240
Flight distance : 319659 ft
This is my mod
I’ve got some boosters too but can not get the 2.4 ones to work it’s worse when I use them
2018-5-18
fans46521240
These are the boys need help
2018-5-18
Mark The Droner
Flight distance : 2917 ft
My understanding is the only amps that are worthwhile are the Sunhans.  I've been using them for years.  They work great.
2018-5-18
fans46521240
Thank you for your reply I’ve seen videos of my cheap things working but you are right mate just ain’t got that sort of money for the big ones thank you for you reply
2018-5-18
Amateur Droner
Flight distance : 6411 ft
sSkyPilot Posted at 2018-1-17 15:16
I made the same antenna mode to my P3S. I was having all the DJI warnings of interference and found my antenna wire was broken (not the plastic) but the wire itself was only a few strands holding on.
The mode cleared up all my interference (including the neighbors wireless WiFi dog fence).
I think you will be happy with the antenna mode, I still have not had the time to check distance/range difference yet. I am just happy to not have a warning every 10 seconds!
2018-5-18
fans46521240
Thank you for your response I’ve think I’ve worked it out I’ve done the magic power mod and turned up the video to 27hz when the boosters can only take as a input of 20hz
2018-5-19
sSunsets
Hi, It's funny how my 6 month old mod is already obsolete... lol... Gonna take P3S out this week for distance tests... Only have  one battery though. The spark is so fun to fly it's been up more than the P3. I'll be back w/details and some pics or video... Thks
2018-5-19
fans46521240
Why’s your mod obsolete?
2018-5-20
sSunsets
Sounds like my 2.4 can be jumped to 2.7 ....
2018-5-20
fans46521240
Looks good but still don’t work with boosters
2018-5-21
