New DT7 Radio and H3-3D with F450
1320 3 2015-4-24
cherschlag
Does anybody know how to make the new gimbal dial on the DT7 radio work correctly with the zenmuse?  Since the dial is spring loaded it always returns to the center.  When you power on the F450, gimbal goes to a 45 degree position.  When you move the dial the gimbal moves up and down, but when you release the dial, it returns to the 45 degree angle.  From what I have read, gimbal is supposed to stop when the dial is released, not return to 45 degree angle.  I don't see anywhere in the naza assistant to select the new radio like you can in the Phantom assistant.  Any help would be greatly appreciated.
Chris
2015-4-24
lasuncion
Guam
I would like to know too. Following this thread!
2015-8-2
DJI-Dave
I have done some research on this and I do not believe they will work together, Sorry.
Dave
2015-12-22
7lkf7
New Zealand
Really ? I was planning upgrade my old ver of DT7 just because I like the dail instead of the dail on the back . But after you inform this issue , I think the old ver of DT 7 works perfect on H3-3D
2016-3-10
