A CW
Flight distance : 14237874 ft
Its omnidirectional antennas placed on the foldable landing gear help increase signal coverage to deliver a maximum range of up to 2.5 miles (4km) with 720p real-time video transmission when flying with the remote controller.
That appears to be the most logical explanation from DJI as to why the range is greater than the Spark though 4KM in FCC and 2KM in CE areas are yet to be seen... And I hope that the small mAh in the battery has enough juice to sustain a safe return on a five mile round flight in modetate winds as using Sport mode to reach 42.5MPH will massively drain that battery and knock the max 21 minutes (16-18 in reality in normal flight) to less than 15 minutes quite easily. My biggest concern flying a WiFi only drone one or two miles away (other than losing VLOS) will be how sensitive the signal is to transmission interference - not sure what the speed is in p-mode and if the drone has dual compass redundancy to help prevent the potential of a fly away. Once more, this drone does not seem to be designed for long distance flying, as is the case with the Spark using the same enhanced WiFi transmission. |
