New firmware upgrade for phantom 4
3403 18 2018-2-5
Dan Morgan
Here we go again.....I see there is a notice on the home screen of my dji go app that says there's a new firmware upgrade.
Considering the outstanding experience I had with the last downgrade....I mean upgrade....I think I'll avoid this one like the plague, I'm not going to upload it.
And if it gets to the point like the last one where it limits my flight altitude/distance unless I do the upgrade, I'm not even going to do the upgrade, I'm going to send it right back to DJI and let them deal with it.
2018-2-5
DJI Susan
Hey Dan, the firmware upgrade is not compulsory, you can ignore if the new update bothers you. Sorry about this.
2018-2-5
Porkhunt
Flight distance : 1417 ft
Good Luck!
2018-2-5
Dan Morgan
DJI Susan Posted at 2018-2-5 18:30
That's what I did with the last upgrade, I ignored it for a while....then it started limiting my altitude/distance, giving me no choice but to have to do it, like some kind of government mandate like Obamacare.
I sure hope this newest downgrade doesn't reach that point, where the operator is forced to upload a defective program/malware.
2018-2-6
phillbarnes
Flight distance : 40367 ft
I'm using it with no problems
2018-2-6
Rodger8
Flight distance : 20145135 ft
I had the same thing happen tome. I ignored the upgrade notice because things were fine and then they bricked my Obsidian. Limited height and distance. Had to do the update.Now the video and GPS are all messed up. DISGUSTING!
2018-2-6
DJI Susan
Dan Morgan Posted at 2018-2-6 06:40
You have logged in your DJI Account, right? Could you post a screenshot of About page? If the issue appears again, please kindly offer the screenshot and flight records for double check, thanks!
2018-2-9
DJI Susan
Rodger8 Posted at 2018-2-6 07:01
Hey Rodger, sorry about this. Do you still remember what's the warning message at that time?
2018-2-9
Rodger8
DJI Susan Posted at 2018-2-9 01:37
Susan, " Update to version 4.2.4" That warning appeared for about 8 flights and I ignored it and then it bricked on me. I thought it was in "Beginners Mode" but it was not.  Height was limited and distance was limited to 100 or 150 feet and no speed. I did the upgrade on site, I have Cellular on my Mini 4 and all was well except for flickering green screen and weak to no GPS after update.
2018-2-10
noflyzone69
Flight distance : 240361 ft
This is so sad DJI still can't get it right!  what is going on in china ? did they put stupid juice in the water?
2018-2-10
fans55ae5496
hey noflyzone, it is more than frustrating how the FW updates seem to cause more problems than they solve.
Your comments are not helpful. Try to post facts and suggestions on how to solve the problem.
Rude comments help nobody.
2018-2-10
Aardvark
Flight distance : 384432 ft
It is the P4 you have, and not the P4 Pro or P4 Advanced ? (This is P4 Pro/Adv' section in forum)
If it is the P4 then the firmware update to 02.00.0700 has received a good response from many, this was one of the original threads started on its release:-
https://forum.dji.com/forum.php? ... D386%26typeid%3D386
At present there may be a problem for some upgrading via Assistant 2, the simplest solution there is to upgrade the aircraft via the DJI Go 4 App'. If you decide to upgrade, then use the latest incarnation of DJI Go 4, as the RC will need upgraded to V1.9.3 (DJI Go 4 V4.1.18 was broken for RC upgrade).
2018-2-11
noflyzone69
fans55ae5496 Posted at 2018-2-10 23:07
2018-2-11
hdlou94
Flight distance : 753163 ft
phillbarnes Posted at 2018-2-6 07:00
you must have top secret clearance..lol
2018-2-11
DJI Susan
Rodger8 Posted at 2018-2-10 11:40
Sorry for the late response. Just to verify, the distance restriction has been removed after updating to the latest firmware, right? Please correct me if there is any misunderstanding. Regarding the green screen, it only appears on image transmission, the original videos play well, right? Please change to another open location with good GPS signal to see whether it helps. Also, keep an eye on the Image Transmission Channels as well.
2018-2-25
Rodger8
DJI Susan Posted at 2018-2-25 01:38
Once I did the update the distance restriction was removed. The green screen is on the image transmission. The GPS issue is due to temperature being below 36F above 38F I have 17 satellites at the same location which is an open field in the country.
2018-2-25
DJI Susan
Rodger8 Posted at 2018-2-25 04:13
Well noted. Which mobile device do you use?  Is there any difference by changing another recommended mobile or location? If not, please kindly export the flight log for analysis, thanks!
2018-2-28
Rodger8
DJI Susan Posted at 2018-2-28 02:13
iPad mini 4 with wi-fi and cellular 128GB
2018-2-28
DJI Susan
Rodger8 Posted at 2018-2-28 04:24
Thanks for the confirmation. Could you refer my previous message for further analysis?
2018-3-2
