IMU Calibration Stuck on #4
9458 9 2018-2-14
N762CB
Flight distance : 513970 ft
Haven't flown my P4 in a few months.  Today I went to get it ready for a flight tomorrow, saw that a firmware upgrade was required.  Performed the upgrade without a problem.  Started it up & it didn't say it needed a Compass or IMU calibration, but I always do one after a firmware upgrade.  Compass calibration completed - no problem.  IMU calibration got thru steps 1 thru 3 and is stuck on step 4.  Front lights on solid RED, back lights flashing fast GREEN.  Tried 2 different Ipads, no change.  Turned everything off & let it cool down for 2 hours.  Tried again - same thing - Stuck in Calibration IMU step #4.  Any help is appreciated.
2018-2-14
Aardvark
Flight distance : 384432 ft
Just make sure the aircraft is positioned exactly as shown on Assistant 2 screen. That is usually the culprit.
2018-2-14
DJI-Mark
You can always reset to factory settings and refresh the firmware through the Assistant 2 Software. After done, please restart everything. Let us know as you need additional assistance.
2018-2-14
userfc87d730c2
Flight distance : 3406 ft
Vietnam
Step 4/6, place the Phantom 4  with its nose pointing down for correction (camera face down to ground)  . Not normal position then it will be fine .
2018-6-1
dwaynedibley
had the same problem, you just need to orientate it like userfc87d730c2 has said although the picture on the screen is not to obvious as wich way to point the drone
2018-6-6
IMRANtv
Flight distance : 29062 ft
userfc87d730c2 Posted at 6-1 21:44
I was stuck at stage 4 also. The image or graphic in the app is not clear about the nose pointing down.  Your quick reply to somebody else literally got it moving again for me. Thank you .
2018-12-8
djiuser_QRsXRqvKfalk
dwaynedibley Posted at 2018-6-6 02:54
Thanks for this tip.  We were stuck at 4/6 stage and did what you said.   Graphics on DJI screen were not obvious for the next position.
IMU calibration successful.
2019-8-28
sedeco
Flight distance : 8060653 ft
Egypt
good  to fix
2019-8-31
RedHotPoker
Flight distance : 165105 ft
That’s great news, that the IMU calibration was finally completed.
RedHotPoker
2019-8-31
Buddhamu
RedHotPoker Posted at 2019-8-31 18:15
Had the same problem and pointing the camera down worked.  It went from step 3 to 4 and step 5 and finally the picture showed having the drone  upright with battery section facing me.  Then it froze and nothing happened... repeat did the same up to 6 saw picture of drone upright battery facing me and put it that way and nothing.... Can't figure this one out... anyone have the same problem?  Any help appreciated.
2020-7-5
