New Phantom 4 Pro/Pro+ Firmware Released (08/03/2018)
1234Next >
38338 132 2018-3-7
DJI Support
Flight distance : 2408 ft
Overview
  • Date:2018.03.08
  • Firmware: V 01.05.0600
  • Phantom 4 Pro Remote Controller Firmware: V 1.4.1.0
  • Phantom 4 Pro+ Remote Controller Firmware: V 1.3.6.0
  • DJI GO 4 App iOS: V 4.2.6
  • DJI GO 4 App Android: V 4.2.6
What’s New?
  • Optimized photo color and contrast.
  • Fixed an issue that occasionally caused flipped live view when the aircraft braked during flight.
Notes:
  • Restart the aircraft and remote controller when the update is complete.
  • If the firmware update fails, restart the aircraft, remote controller and DJI GO 4 app or DJI Assistant 2, then try updating again.
2018-3-7
Tearuup
Flight distance : 123763 ft
Just received my Phantom 4 pro + today.  Been reading about the firmware issues.  Hope this works.
2018-3-7
KedDK
Flight distance : 1133038 ft
Denmark
Thanks for also updating the Release Notes this time but when are you going to add all important details?
No where is it shown where ex. the ID broadcast was put on our crafts.
When will you update the manual to reflect current features and limitations?
2018-3-7
yosephat
Flight distance : 724570 ft
Indonesia
is it already tested?
2018-3-7
15matjan
Flight distance : 1158258 ft
yosephat Posted at 2018-3-7 23:34
Volunteers welcome
We'll figure out in the following days.
Jokes apart, I'd have liked to know more about "what" was optimized in terms of camera, image and picture control, as being something which is critical for most of us
2018-3-8
FarmerMac
Flight distance : 1215079 ft
Denmark
What about the vibration problem that might be the reason the
vent-cracks occurs.
Thats actualy my biggest concern, if it's related to the "old" firmware.
2018-3-8
dronybaloney
Flight distance : 24897940 ft
Dji ? Can you confirm if the vibration problem upon landing/startup has been solved? If not i will not update. Please let us know. Also the video transmission image been improved?
2018-3-8
Mafia16
Flight distance : 26490948 ft
Dominican Republic
lets BETA test these one
2018-3-8
bernardren07
Flight distance : 48504 ft
Singapore
Thank you for update latest firmware. i going to test it
2018-3-8
Giammi
Flight distance : 847795 ft
Will this fix the wobbling arms issue as well? I will give it a try anyway.. maybe it helps..
2018-3-8
dronybaloney
Giammi Posted at 2018-3-8 06:17
Let us know the results please
2018-3-8
fansf8629e18
Flight distance : 422933 ft
I just tried to update to the latest firmware but it does not even come up in the dji go 4 app, it says I’ve got the latest WTH
2018-3-8
Nelsonlee
Flight distance : 2779203 ft
Malaysia
fansf8629e18 Posted at 2018-3-8 07:14
Just connect your aircraft to PC and run DJI Assistant 2 software to update the firmware.
2018-3-8
fansf8629e18
dji go 4 logged out of the account thatswhy.....meh. Got the new firmware installed, here is hope that all major issues will be resolved:p
2018-3-8
Dublinphantom
Flight distance : 1033222 ft
Please let us know. I held off on the last one because of the image flip issue, discoloration and landing wobble issues. if they're not fixed, I will still hold off. I don't usually like to hold off on updates but the fact they released this one so soon shows they knew the last one was very bad.
2018-3-8
Nelsonlee
Malaysia
Firmware update done.....
2018-3-8
Nebuchadnezzar
Flight distance : 3462946 ft
Volunteers to face the fear !!
2018-3-8
Nebuchadnezzar
Best wishes Dudes !!!
2018-3-8
FatherXmas
Flight distance : 4058619 ft
Downloading it now. I'll try to head outside and fly a battery at lunch today.
2018-3-8
Genghis9
Flight distance : 961 ft
KedDK Posted at 2018-3-7 23:23
Extremely great point
However, der commissar does not have to let the peasants know when they change things for their benefit...
2018-3-8
Genghis9
Has anyone had any results up or down?
2018-3-8
RMJovo
Flight distance : 1716240 ft
Genghis9 Posted at 2018-3-8 11:21
Updated the P4P+ today took it to the park for test flight Quad performed OK controller had temperature problem (28 deg F) screen totally unstable due to temp. Only problem I have is getting the change from 2.4GHz to 5.8GHz to work correctly when I switch we have a loss of link, I have discovered a work around. But it is still a pain not to have the frequency switch go without a hitch.
2018-3-8
Hellsgate
Flight distance : 1991555 ft
Think ill hold off for a while dont want to loose my drone for yet another 6 weeks while it gets repaired again lol
2018-3-8
Genghis9
RMJovo Posted at 2018-3-8 13:06
Did you try auto setting to see if that worked as needed or you prefer not to go that route?
Issues may have all been related to temp...let us know how it goes when you fly next in more moderate temps and conditions.
Cheers
2018-3-8
RMJovo
Genghis9 Posted at 2018-3-8 14:20
Cheers
Auto and manual have the same problem on the switch of the two frequencies I have seen other threads were others are having the same problem, my workaround is to go into the controller and put the controller into the 5.8Ghz mode first then power up the Quad that prevents the loss of link.
2018-3-8
Genghis9
RMJovo Posted at 2018-3-8 16:06
ah...to be clear on my end, loss of link between quad and RC or ?
2018-3-8
alqahfi
Indonesia
i've been upgrade this firmware and guest what, there is some bug, now i cant fly my drone
2018-3-8
RMJovo
Genghis9 Posted at 2018-3-8 17:16
Yes Between Quad and RC. Started with the last update for the RC. The controller update in the first part of Feb for the P4P+
2018-3-8
Genghis9
RMJovo Posted at 2018-3-8 19:15
Gotcha
This would explain why I have not seen this issue, I don't have the P4P+ just the plane ole P4P
Well let us know if you get any more updates for this, please?
2018-3-8
Jenee 2
Flight distance : 7852129 ft
I haven't flown yet but just be aware that the update resets all the camera settings.
2018-3-8
fans13642d5f
Flight distance : 3406883 ft
Well after waiting 2 months for the revised firmware it still doesn't do what it said it could do.
Pano mode still not working, does not capture beyond 10-11 images with "Failed to Capture" message every time. The inverted camera and horrible yellow images have gone but why doesn't Pano mode work?
Will this be fixed or should I just write off Pano mode?
2018-3-9
Giammi
dronybaloney Posted at 2018-3-8 06:54
Just updated it and looks like the wobbling issue has gone. To be honest, I didn't fly yet. I just idled the motors in my house and try to pull it up. With previous firmware the issue was already present. Now there's no trace of it.
Tomorrow, if the weather will assist me, I'll fly it, just to make sure that everything is fine.
2018-3-9
Giammi
DEUCEDOG Posted at 2018-3-9 10:05
Just updated also but not able to fly yet due to rain but i did notice the ac ID is off by default now not on , even after restart  it remains off
What do you mean with ID?
2018-3-9
Giammi
DEUCEDOG Posted at 2018-3-9 10:50
UUID that was in a previous fw update in December , it emits a signal with your registration number etc when you fly . it was originally set on as default .
Ah ok got it. Never dig into this. I'll give it a look this weekend. Thank you
2018-3-9
Mobilcams
Flight distance : 2907674 ft
FarmerMac Posted at 2018-3-8 01:32
vent-cracks occurs.
Well I can attest this has happened to mine but I didn’t know this was the reason. I noticed today after updating the firmware that it was shuddering when it landed and now have a crack. Funny thing is today’s the one year anniversary of activation and they are telling me I’m probably out of luck on the warranty.
2018-3-9
S.D. Pilot
Flight distance : 10278435 ft
Glad it appears to have fixed the inverted camera issue which is why I'd downloaded to 0300. I'm thinking of giving this newer FW a shot and will test over the weekend.
2018-3-9
vidya
India
If in give the latest firmware update is there any problem like fly only till 30 metres
2018-3-9
AlexVideoShark 5
Flight distance : 4535200 ft
after reading all these comments I have even more fear than before ...
my P4P is going very well ... panoramic photos works well, and also all the other functions,
always lands well (almost always manually) ...
only once the screen has reversed ... while filming from above to down, moving back ... but only that time ...
honestly I'm not sure I have to update him
2018-3-10
Bartiflier
AlexVideoShark 5 Posted at 2018-3-10 00:03
So does this update fix the 1080p Sharpness bug, where all settings of video sharpness from -3 to +3 are identical and look like about +2?
Works in 2.7k and 4k, just not in 1080p, making it useless.
2018-3-10
Giammi
Sorry to inform you that the wobbling issue is still there. Both in take off and landing. I have a couple of videos that are showing it pretty well. I made them just to have something to use as proof for warranty in case of any crack in future.
2018-3-10
1234Next >
