Update 2 Analysis program
123456789Next >
37401 326 2018-4-25
JJBspark
Flight distance : 12260774 ft
Hiya,
For Window-users i have an update of my own flight record analysis program.
Feel free to use it, any ideas to make it better, do sent me a mail or post it on here.
Cheers JJB
see this now >
https://forum.dji.com/thread-203659-1-1.html
FRAP UPDATE
03 OKT 18 / Update version 3.8 > link removed
17 OKT 18 / Update version 3.9 > link removed
14 JAN 19 / Update version 4.4 > link removed
5 DEC 19 /  Update version 5.4 > link removed
Feel free to comment and/or ideas to improve this program!
Registered users check your mail.
example
example
2018-4-25
LouisP
Flight distance : 41952 ft
Thanks... I was able to switch my decimal separator back to a dot instead of a comma :-)
2018-4-25
JJBspark
LouisP Posted at 2018-4-25 12:23
Its my pleasure. And yes, its now a option to set the right decimal separator!
2018-4-25
G_Sig
Flight distance : 9109311 ft
Iceland
JJBspark Posted at 2018-4-25 12:44
What am i doing  wrong?
2018-4-25
HedgeTrimmer
If you can compile a "OS X" version, I would like to give your FRAP a try.
2018-4-25
DJI Diana
Flight distance : 2408 ft
Sounds great.
2018-4-25
JJBspark
Hi,
Not much...When the programm is running uh  read the help txt under the button.
Open the options menu and click on configuration, set the 3 directory`s where the programm searches for the txt files (i.e.x:\frap\txt1  and 2 and 3.
But first download that conversion file * and put that in the same dir as the exe file.
* latest version is april 2018.
cheers JJB
2018-4-25
JJBspark
HedgeTrimmer Posted at 2018-4-25 13:43
when i can find some time....mayby i will do that
2018-4-25
G_Sig
Iceland
JJBspark Posted at 2018-4-25 23:05
Hi,
Ok had just made the OWNTXT not  1 an 2. Thanks
2018-4-25
JJBspark
Thanks Diana, it works great
Just to give the user more understanding what is happening during flight and what he/she could do better in certain situations. Next is to make a DO and DON`t  (check) list.
Ofcourse we need DJI to make a final assesment if it goes 'wrong'  in any way.
cheers JJB
2018-4-25
JJBspark
G_Sig Posted at 2018-4-25 23:12
Well, names for directory`s are free, just set the path correct in the program.
Let me know if its works!
2018-4-25
Bokepacha
Flight distance : 149265 ft
Thanks! I'll give it a try this weekend.
2018-4-26
QuadKid
Flight distance : 482349 ft
Thank you JJB for your work and generosity for sharing the FRAP, much appreciated !!
2018-4-26
eried
Flight distance : 661362 ft
Denmark
Cool! thanks!
I noticed 2 small issues: The window position is not remembered (I have 3 screens and the window appear offscreen every time). It would be nice to have "Export" functionality in the tables and charts.
2018-4-26
JJBspark
eried Posted at 2018-4-26 01:02
Cool! thanks!
Indeed a minor issue ; i have just one large screen....(but see what i can do ofcourse)
About the Export function; the CSV file is there as well, so most of the data can be filtered there.
Which specific data (from wich view) do you like to export?
cheers JJB
2018-4-26
QuadKid
Hey JJB, d/loaded the program, I know I have or have not done something right, any help appreciated, video below
2018-4-26
Tealk
Flight distance : 479613 ft
Romania
i think it`s not working on windows 10 ... i made 3 directories named txt1..txt3 and set in configuration for p1...p3...i put a flight record data there from mavic in txt1  and it`s not opening ...
2018-4-26
eried
Denmark
JJBspark Posted at 2018-4-26 01:25
Thanks!
I know the CSV is there but when I see it in your program it is filtered (for example exporting only the PR data, or the values from the Controller graph)
2018-4-26
JJBspark
QuadKid Posted at 2018-4-26 01:49
Hi,
Almost there, why cancel ? your flightrecord containts more than 9999 records.
make a choice in that. or the first 9999 or the last 9999 records to load.
Thanks for this video, strange to see that the loading screen is not shown where it shoud be...same for the text on the 3 buttons, does not fit.
Have to look into that ; what lettertype is your default setting ?
cheers JJB
2018-4-26
JJBspark
Tealk Posted at 2018-4-26 02:02
Its made on a W10 computer, on my computers (all windows 10 machine) it does work.
Did you download that conversion program and put that in the same dir as the exe ?
In the menu choose options/configuartion and set the path correct for the 3 dir where you have the txt files
cheers JJB
2018-4-26
G_Sig
Iceland
JJBspark Posted at 2018-4-26 07:49
Hi,
Have seen the same. Running this on laptop  and it's missing  the lowest part of the screen.
2018-4-26
Tealk
Romania
JJBspark Posted at 2018-4-26 07:52
yes ...i made everything correct
2018-4-26
QuadKid
Hi,
Hey JJB, Ok followed thru to load first files, it responds the same way if I select Last Files as well (See below)
2018-4-26
Montfrooij
Flight distance : 2560453 ft
Thanks a lot.
I will save it for when I have my next drone
2018-4-26
JJBspark
QuadKid Posted at 2018-4-26 10:19
https://www.youtube.com/watch?v=7gk4ZYHXbK8&feature=youtu.be
Not at home now, will look into this next monday
2018-4-27
QuadKid
JJBspark Posted at 2018-4-27 03:14
Thanks friend, no rush, much appreciated!
2018-4-27
QuadKid
Good Day JJB, I have inserted a flight log and procedural video of the error I'm getting. Windows 10Home / x64. Here is the Flight Log:
http://www.phantomhelp.com/LogViewer/3XTCZQ1YY8N2YFLOJ5AG/
2018-4-29
JJBspark
QuadKid Posted at 2018-4-29 07:58
Thanks, did you set the decimal separator to the correct one? option/configuration.
Downloading now,  see what i get for an error code
cheers JJB
2018-4-29
JJBspark
Hi QuadKid, guess i found the problem. Your txt file is converted with 4 lines (one example copy paste) wich doesn`t show the standard date time conversion format.  See if ican work around that strange conversion phenomen.
cheers JJB
2018/04/20 15:07:42.898  (standard)
20-04-18 15:07 (gives the error in my program)
2018/04/20 15:07:43.101 (standard)
2018-4-29
QuadKid
JJBspark Posted at 2018-4-29 10:32
cheers JJB
Thank you my friend, much appreciated. Not to savvy when it comes to coding and things. What is the correct decimal separator ? I will look at the help file again. Thanks.
2018-4-29
JJBspark
QuadKid Posted at 2018-4-29 10:44
Comma or Dot, depends how your windows settings.
btw, fixed 'your' error. Some minor bugs to fix, tommorow a update.
2018-4-29
QuadKid
Thank you JJB !
2018-4-29
HedgeTrimmer
cheers JJB
Welcome to fun world of computers where Standards come with Exceptions too.
2018-4-29
JJBspark
HedgeTrimmer Posted at 2018-4-29 12:09
well, i did join that world many many years ago....still some unexpected surprises!
2018-4-29
G_Sig
Iceland
JJBspark Posted at 2018-4-29 12:20
Any known reason for this error?
2018-4-29
JJBspark
G_Sig Posted at 2018-4-29 12:59
[view_image]
Hi, my first guess is setting for the decimal separator. See post earlier.
If not, do sent me your flightrecord.txt file; i will check whats causes this error.
cheers
JJB
2018-4-29
G_Sig
Iceland
JJBspark Posted at 2018-4-29 23:27
Decimal separator don't change anything, it also happen on flight log QuadKid posted in post #27.
http://www.phantomhelp.com/LogViewer/Z63EWZBZUHW4VPVQGEKI/
2018-4-30
JJBspark
G_Sig Posted at 2018-4-30 01:13
No problems here with loading your file....(hmm, what is the problem...)
2018-4-30
Axeli
Flight distance : 339416 ft
Czechia
I have the same problem like G_Sig
2018-4-30
QuadKid
Hey JJB updated as per instruction same result, Ouch Brain Ache, ran System File Checker using Administrative Command Prompt, no errors indicated, Thanks again for your help
2018-4-30
123456789Next >
