Is there a way to change the return altitude for good?
1629 2 2015-5-13
adot
There used to be a way for my phantom 2 vision and my SJ1000 to set the return to home altitude and it stores it forever.  It was on the app loaded onto my macbook. I found the spot to change the setting on the dji pilot app for my phantom 3. However is resets back to default after you power off the drone. I have always had a higher return altitude so it would go over trees at least.
Thanks,
Anthony
2015-5-13
SAFAERIALS
Flight distance : 93146 ft
Dominican Republic
I have read and have the same problem and theres some threads about it and nobody from DJI in this forum have answered anything! they should a least tell us that its a bug un the app and should be solve in the next update
2015-5-19
DJI-Autumn
Do not understand it clearly. You mean the RTH altitude resets back to zero in pilot? Or reset to default value (20 if I remember correctly).
I've mentioned it's an UI bug and will be fixed in next app version.
2015-5-22
