Inspire 1s Lightbridge does not work if you live in Norway!
1205 4 2015-5-14
DrPhil
Norway
With the new updates that changed the channels from 32 to 8 channels now mean that the lightbridge simply does not work in norway!  the remaning channels can not connect to the video feed. Why??. i have tried to fly it at 8 tottaly different locations here in norway and it does not work. I have even tried to drive far out into a forest area and the signals where so week that no connection were made. You apperently need a amature radio licence here in Norway to use the channels that work.
If you live in norway and have no problems pls contact me.
2015-5-14
triise
Flight distance : 1303471 ft
Norway
Funker som fjell i nord-norge i alle fall. Har ingen problemer.
Hvordan ser det ut i app'en når du sjekker kanalene?
(Vi kan jo ta resten av den norske diskusjonen på PM)
Tore
Riise Foto
2015-5-14
nilsblix
Flight distance : 23047543 ft
Hva ????
Er det ikke bare en kommunikasjon mellom Inspire og Remote - Ser ikke at det er mulig at det ikke virker i Norge.
Trenger en forklaring på dette - da jeg skal på ferie med min Inspire i sommer.
Dette tror jeg simplethen ikke noe på
2015-5-14
nilsblix
I am going to Norway on holliday this summer - and bringing my Inspire
IMO the lightbridge should work as normal in Norway - the communication is between the remote and the bird and not dependent of any other networks.
I have been wrong so many times in my life that I might bee wrong now also - but that lightbridge should not work in Norway does not make sense
2015-5-14
markjacobs.talk
Flight distance : 120784 ft
Can you please tell me what is different in Norway? Although not a member state, my understanding is you abide by the European spectrum allocation?
European Frequency Allocations
2015-5-14
