Zenmuse H3-3D problem, vibration during the flight.
5671 13 2014-11-2
2APro
Russia
Hello,
The problem is rocking of gimbal during the flight.
Please find attached youtube video with description. Please find attention that there is not any wind this day.
Thank you
2014-11-2
efimov.andrey.n
Flight distance : 5587346 ft
Russia
Same issue
2014-11-2
Tahoe_Ed
Flight distance : 2605 ft
Make sure that you are not in FPV mode.  Also do the advanced IMU calibration and see if that helps.
2014-11-3
2APro
Russia
Tahoe_Ed Posted at 2014-11-3 22:26
Make sure that you are not in FPV mode.  Also do the advanced IMU calibration and see if that helps. ...
Hello Tahoe Ed, no, the FPV mode is switched off and calibration didn't help us unfortunately
2014-11-4
Tahoe_Ed
What vibration isolation balls are you using.  We are currently getting good results on the firm white balls.  You don't say what craft you are flying the H3-3D on.  Have you balanced the props, motors etc.  Vibration on the craft can translate down to the gimbal.
2014-11-4
2APro
Russia
Tahoe_Ed Posted at 2014-11-4 20:36
What vibration isolation balls are you using.  We are currently getting good results on the firm whi ...
Hello,
we are using white balls from the box, we got the Phantom 2 recently. The props are the new ones, we changed them, but it gave no results. The motor is not balanced, but I should notice that the Phanton without props is not buzzing around the table, like it was described in following video (2 min 10 sec)
2014-11-4
Tahoe_Ed
Please set your gains at the default values for the Phantom 2.  Are you using the retaining clips?  If so are they only attached to the first click not the second one which compresses the ball and causes vibration.
2014-11-4
2APro
Russia
Tahoe_Ed Posted at 2014-11-4 22:02
Please set your gains at the default values for the Phantom 2.  Are you using the retaining clips?   ...
Hello, thank you a lot for prompt response, the gains are in default values, we are using the retaining clips and they attached to the first click.
2014-11-4
Blade_Strike
Flight distance : 872694 ft
Can you try a different set of props?
2014-11-4
2APro
Russia
yes, we tried, it didn't help
2014-11-5
Blade_Strike
Please try the grey dampeners
2014-11-5
sergey_diesel
Russia
Hello
After update Zenmuse H3-3D from 1.0.0.4 to 1.0.0.10 I have vibration problem!
http://youtu.be/S4UJfgh2670
The problem arises in flight mode. Video taken in no wind days. At the end of a fragment of a video shot before the upgrade gimbal (old version 1.0.0.4 was from the factory) After the update version is 1.0.0.10.
Before the flight, I produce Additional IMU calibration and Basic calibration of the gimbal through the Phantom 2 Assistant 3.4 software. What do I do now? I have a defective shoot ((( Please help!
2014-11-29
sergey_diesel
Russia
Hi friends! I solved the problem of vibration Zenmuse H3-3D gimbal.  Instal Anti Interference Board for Zenmuse H3-3D into Phantom 2.
See video http://youtu.be/RzBQS3tEqJE
2014-12-1
kaselsk
Flight distance : 56585 ft
Latvia
Try use anti-inteference board
2014-12-13
