I am configuring my A2 with my Spectrum DX8 transmitter. I have adjusted the travel for the AUX1 channel so that the control mode changes correctly however if I switch the transmitter off, the A2 does not trip into Failsafe mode. Unfortunately the instructions are not helpful. Does anyone have any suggestions on what I should do to make it work please?
Tahoe_Ed Posted at 2014-11-3 03:22
Does the LED show loss of signal? If so you are in failsafe. You should also see this in the Assis ...
I get a blue flashing LED but in both the Windows and mobile app, although the transmitter shows as disconnected the status does not flip over to Failsafe.
The transmitter and A2 receiver/satellites appear to be binding correctly (DSM2 / 22ms) and everything else seems to do as expected although not tested in the field.
I have tested numerous times in the field using both the RTH switch and turning off the Tx. It does work. I would recommend that you use the switch first. I hate turning off a good Tx. You understand that you can switch between GPS and ATTI to regain control of the craft at ant time.
On the RTH switch it shows the change happening (having RTH switch is all well and good until I need that channel for something else but it is no good in a loss of signal situation).
It is just in the control mode screen of the assistant software not showing the change. This makes me very nervous as I'd like to be sure that the Failsafe functionality works on loss of signal - I don't feel comfortable with it at the moment.
Thanks. I will test it out for real although I would still prefer to see it working as it is meant to first.
Unless others with my set-up can configure their machines according to the instructions and see it working, it would appear that there may be an Assistant software "feature".
Not all Spektrum Rx,s will fail safe, I fly electric fixed wing, Just moving to Quadcopters,
Some of the lower channel Rx,s when the signal is lost just shut the motor down.
But He is using the built in a2 rx with satellites. So he does not have to worry about that. You are correct though, the lower end spectrum rx's do not support a user programmable fail safe.
