Dear, my name is Federico, I'm from Villa Carlos Paz, Cordoba, Argentina.
Buy a couple of days ago a phantom 2 vision plus v3.
Charge the batteries properly, install the app, synchronize with my S5, do the compass calibration and make engines run slightly, there my surprise, an engine fails. Micro cuts ago, apparently it works rpm q unless the other three and suddenly to zero and starts spinning again.
Attached link to the video:
In my ignorance I thought q could be solved by loading the new firmware, so did the latest version and nothing, the fault persists. The store where buy far more than 1200 km.
I made a great effort to buy it and I could not even make a flight.
I am very sad and even more disappointed, I appeal to your kindness if someone can help me solve this issue.
regards
Do not try and fly it because it will crash. Contact the vender and see what they will do. The same thing happened with the first phantom I got but it was a lot worse. The vendor e-mail me a prepaid return label and gave me a full refund including shipping.
After look at the video again looks like no red led is on that arm so a bad ESC. the only way to fix it is replace it.
What mode do you have the RC in? Not sure I quite understand the issue. Connect the Phantom to the assistant software and ensure your RC is in mode 2 which places throttle control to the left stick. Also if the RC has the thumb wheel for gimbal control on the side make sure in the assistant software the RC is set for the upgraded version. A few months ago, I updated the firmware on my RC which defaulted it to Mode 1. The only thing I could do was start the motors and it acted like yours. Little did I know the throttle was on the right stick. Other than that I would contact DJI rather than drive 1200 kilos.
Appears that the motor controller is bad(ESC). See if your dealer will exchange it for you. If not ask for a refund. If you send it into DJI for repairs you are talking two months minimum. Good luck!
