david.p.mann
Flight distance : 18669501 ft
If the black lines you are seeing show up on recorded video on the SD card, these lines are most commonly caused by propeller shadows being cast on the lens. This most frequently occurs when you have the lens pointed nearly straight forward (0 degree angle), and you are flying forward (or are hovering with the camera facing into a strong wind), and sun is nearly directly overhead. Under this scenario, you often can see the props in the top of the video frame as well. However, I have seen prop shadow/flicker in recorded video even when the actual props are not visible in the video frame.
There are two ways to avoid/eliminate prop flicker from your videos: 1) angle your camera lens down another 10-15 degrees (if you can still get your shot), or 2) buy a third-party petal lens hood for the P3 camera lens. Several can be found on eBay. |
