New Release Notes For .500 FW
123456Next >
15845 210 2018-9-26
hallmark007
Flight distance : 9827923 ft
Update still not showing when starting Aircraft, but looks like it’s imminent, hope it helps those having problems. And enhances aircraft for all.
Mavic Air Release NotesDate :
Aircraft Firmware :
Remote Controller Firmware : DJI GO 4 App iOS :
DJI GO 4 App Android :
What’s New?
2018.09.26 v01.00.0500 v01.00.0200 v4.3.0
v4.3.0
    Aircraft:
 Fixed the issue where the aircraft behaved abnormally when it misidentified a subject in ActiveTrack.
 Fixed the issue during RTH where the aircraft continued to fly backward when it sensed obstacles both in front and behind.
 Fixed the issue where the time displayed on photos was incorrect.
 Fixed the issue where the aircraft flight distance was still restricted despite the Distance Limit being
disabled in DJI GO 4.
 Fixed the issue where the abnormal current warning appeared too frequently in some situations.
 Fixed the issue where the aircraft could not land due to issues with the remote controller control sticks.
Remote Controller:
 Added the ability to adjust the camera parameters. Press and hold the customizable button and toggle the gimbal dial to adjust.
Notes:
 Make sure you update the DJI GO 4 app to the latest 4.3.0 version or higher before updating the firmware.
 Restart the aircraft and remote controller after the update is complete.
 Please note that the firmware update may reset various Main Controller Settings, such as the RTH Altitude and Maximum Flight Distance, to factory defaults. Before the update, take note of your preferred DJI GO 4 settings, and readjust them after the update to suit your preference.
 This firmware update resets the camera settings.
 GEO zone authorization will be disabled after this firmware update. Please reinstall it again.
 If the firmware upgrade fails, restart aircraft, remote controller and DJI GO 4 or DJI Assistant 2, and retry.
http://www.dji.com/mavic-air
Copyright © 2018 DJI All Rights Reserved. 1
2018-9-26
Ulysses Paiva
Flight distance : 573310 ft
Where did you get it?
2018-9-26
hallmark007
I got it from downloads on the dji website, I would imagine it will be rolled out over the next few days,
2018-9-26
dont slow down
Flight distance : 574977 ft
This is an android DJI Go4 app update, not an aircraft firmware update.
2018-9-26
hallmark007
dont slow down Posted at 2018-9-26 07:26
No it’s not it’s .500 FW, if you read the notes above it is pretty clear what it is.
2018-9-26
Keule
Flight distance : 3733015 ft
Maybe that's clearer:
2018-9-26
cinnabun
Flight distance : 812995 ft
Is it though? It does say "Aircraft Firmware : v01.00.0500"
2018-9-26
dont slow down
That is clearer yes, the first post had the version number under the DJI Go4 Android part. My mistake. I hope this fixes more issues than they listed there.
2018-9-26
hallmark007
dont slow down Posted at 2018-9-26 07:38
Hopefully it will fix all FW issues, but we must remember that not all issues are FW related.
2018-9-26
Ulysses Paiva
The date is today so,,, anytime now. Just checked and not available yet.
2018-9-26
Ex Machina
Flight distance : 1806362 ft
hallmark007 Posted at 2018-9-26 07:42
Interesting that the Air .500 release notes differ from the MVP .500 release notes -- does this mean the fixes only apply to the Air model? The upload dates differ for the two as well with the Air version being the most recently posted.
2018-9-26
Optimus_Prime
Flight distance : 568704 ft
Vietnam
Have just plug my MA to assistant 2, does not show up yet. Definitely take a day off from work to check it out deeply. So waiting
2018-9-26
saviour
Flight distance : 604203 ft
Wow, it's really happening? Didn't expect that! But I am not sure whether I should update because I don't have big issues and this firmware could cause more issues than solving for me. :/
2018-9-26
hallmark007
Ex Machina Posted at 2018-9-26 08:10
Yes only apply to Mavic Air, I think it’s just a coincidence that both seem to be on the same numbers.
2018-9-26
hallmark007
saviour Posted at 2018-9-26 08:25
Well nothing there about not being able to roll back, it does say you need to be on the latest app, so if you intend to be able to roll back, you may need to roll app back to remain with your status quo,
2018-9-26
Charissa
Flight distance : 689334 ft
South Africa
Interesting point,
Fixed the issue where the flight distance was restricted ...............................
Anyone had that problem?  Could it have anything to do with the fact that I could not get more than 800 meters distance out of the drone?
2018-9-26
Rblomqvist
Flight distance : 1026260 ft
Just checked and it's not yet available for me in the US (Florida), has anyone been able to download/install it? Not sure if all DJI servers will get at the same time.
2018-9-26
hallmark007
Charissa Posted at 2018-9-26 09:04
Interesting point,
It was basically to do with some not being able to fly outside beginner or not signed in restrictions, so it was limiting some to beginner distance, so I believe your limit was distance 100 metre height 20/50, it had nothing to do with craft not flying as far as advertised, you would get warning on your app that you were restricted to flying any further.
2018-9-26
Charissa
South Africa
hallmark007 Posted at 2018-9-26 09:32
I was hoping...........
2018-9-26
DJI Stephen
Thank you for sharing some Information, Regarding the release note, you may refer to this link https://dl.djicdn.com/downloads/ ... elease_Notes_en.pdf
2018-9-26
saviour
hallmark007 Posted at 2018-9-26 08:29
I don't even have the latest app because many people report that the latest app works very bad (laggy transmission) on Android Phones.
2018-9-26
hallmark007
Charissa Posted at 2018-9-26 09:35
Ah well, good things always come with new FW, but sometimes not all good, hopefully new FW and combination of new SW will give you what you need.
2018-9-26
hallmark007
saviour Posted at 2018-9-26 09:44
Well it says in the notes you need to have app updated, but if everything is working ok you have the option of staying where you are.
2018-9-26
InvisibleName 7
Flight distance : 795653 ft
But would you want to roll back to .400?
2018-9-26
hallmark007
InvisibleName 7 Posted at 2018-9-26 09:58
Yes there is, on page 2 of release notes it states that you can’t roll back!
Ok so my mistake. Sorry.
2018-9-26
InvisibleName 7
hallmark007 Posted at 2018-9-26 09:59
No, my mistake - page 2 is the previous version’s notes. So maybe you can
2018-9-26
hallmark007
Actually looking at it again second page refers to .400 and that you cannot roll .400 back, so unless you have another page you can post, you should be able to roll back to .400
2018-9-26
Wachtberger
Flight distance : 261509 ft
Great news for those who have experienced issues. The release notes also make it clear which issues were indeed firmware related and which were not. I can only hope that this will be understood. Other issues reported previously might have been related to DJI GO 4 or simply to the mobile devices used (with their particular setup, e.g. plenty of other apps running in the background or whatsoever). While it is easy to attribute any perceived problem to a new firmware, it is in a number of cases factually not correct.
And I really hope that this time all who update the firmware through DJI GO 4 will do so with version 4.3.0 or above as stipulated in the release notes. The safest way will be to do it with DJI Assistant.
2018-9-26
djiuser_lPCQ6tHgHjvC
Flight distance : 616732 ft
I want to see what camera parameters you can adjust with the wheel!
2018-9-26
LookAt_Wictim
Flight distance : 2621982 ft
Slovakia
djiuser_lPCQ6tHgHjvC Posted at 2018-9-26 10:27
i think E.V. , Shutter speed, ISO like in mavic pro !!
2018-9-26
LookAt_Wictim Posted at 2018-9-26 10:30
That will be nice if so.
2018-9-26
Charissa
South Africa
Wachtberger Posted at 2018-9-26 10:12
Great news indeed for those who have experienced issues. The release notes also make it clear which issues were indeed firmware related and which were not. I can only hope that this will be understood. Other issues reported previously might have been related to DJI GO 4 or simply to the mobile devices used (with their particular setup, e.g. plenty of other apps running in the background or whatsoever). While it is easy to attribute any perceived problem to a new firmware, it is in a number of cases factually not correct.
And I really hope that this time all who update the firmware through DJI GO will do so with version 4.3.0 or above as stipulated in the release notes. The safest way will be to do it with DJI Assistant.
Don,t really want to argue the point, but i do not agree fully.
It does not mean that it was NOT firmware problems that some people had, just because the fix is not in the new firmware update release notes.
Some of the problems could very well be firmware related, but like a couple of other problems, not attended to at the moment.
That been said, I do hope that my (repaired....) drone, will be more stable with the update.
I for one, am really tired of spending around 20% of my battery, just to connect the drone to the remote, then another 20%, just to get the compas calibrated, then another 20%, just to get the signal to rc loss restarted, dji app restarted..........you get the gist.
Would love to just enjoy my drone for a change.
2018-9-26
Ulysses Paiva
Brazil
Its funny because its dated today and untill now no official announcements here on the forums nor anything available to be updated so far.
2018-9-26
LookAt_Wictim
Slovakia
Ulysses Paiva Posted at 2018-9-26 10:49
few hours left im waiting and praying
2018-9-26
Wachtberger
Charissa Posted at 2018-9-26 10:43
After all the uproar we have seen here in the forum after the release of the .400 firmware you seriously believe that DJI would have chosen not to address issues that had been reported if they were firmware related? After having made those concerned wait for such a long time? Deliberately going for the next uproar? Please, take some time to think about this. And sorry, if you spend 20% of your battery time connecting your drone to the RC before each flight and all the other things you have listed, you certainly have problems, just these are clearly not firmware related.
2018-9-26
hallmark007
I think this will start rolling out tomorrow, this is normally what we see, I expect it to show as a sticky very soon. I can see your tongue is hanging out waiting for this update (;+)”””””;;;;;;;
2018-9-26
KlooGee
Flight distance : 16783757 ft
Thanks for sharing!
2018-9-26
Wachtberger
hallmark007 Posted at 2018-9-26 11:00
I forgot to thank you for sharing the good news with us. Great job to have spotted it on the download website, thank you very much!
2018-9-26
JamesPigeon
Flight distance : 1234980 ft
Norway
Good catch, but i am a but disappointed that we are not able to silence the RTH beeping on the remote yet.
And do you guys think we will ever see hyperlaps on the DJI GO 4 app for our loved mavic air?
Also I have never had any issues with any of these fixes they are applying to v.500.
2018-9-26
LookAt_Wictim
Slovakia
JamesPigeon Posted at 2018-9-26 11:18
Make hyperlapse in post process, it takes 3-5 minutes of your time
2018-9-26
123456Next >
