cable hdmi phantom 3
asfodelo42
There is a cable to connect the Dji Phantom 3 to tv hdmi?
thanks e regards
2015-6-2
john.lambert4
No sorry this isn't possible.  Only option is to either connect a laptop/PC to the TV that can read your videos on the SD card, or via USB drive/HDD plugged into the TV with the video files on it.
2015-6-2
Tahoe_Ed
Flight distance : 2605 ft
Not at this time.  There will be a board that can be added which will allow for HDMI output.  It is not out yet.  Give it a month or so.
2015-6-2
salota8550 This user has been deleted
2015-6-2
Tahoe_Ed
You can do that if you happen to have an Inspire Tx.
2015-6-2
asfodelo42
thanks for the reply but I do not have a tx Ispire, there is a USB cable from phantom 3 advanced to hdmi?
2015-6-3
NorthernLoop
Flight distance : 300246 ft
Tahoe_Ed Posted at 2015-6-3 10:44
So you don't need to have you P3 control on as a master and then use the Inspire as Slave? I can just use the Inspire controller as a master single unit?
Inspire control is expensives, what at the chances that Dji will add HDMI to P3 in the next 6 months? That would be a lot of money wasted on the controller if so.
2015-6-3
Tahoe_Ed
asfodelo42 Posted at 2015-6-3 18:26
thanks for the reply but I do not have a tx Ispire, there is a USB cable from phantom 3 advanced to  ...
No there is no such adaptor.
2015-6-3
Tahoe_Ed
NorthernLoop Posted at 2015-6-3 20:29
So you don't need to have you P3 control on as a master and then use the Inspire as Slave? I can j ...
Correct.  I believe that based on the emails that I have received that it will be significantly less than 6 months.  There are several of us testing the board right now.  Works well and you have dual output to your device and HDMI.
2015-6-3
acollinsdal.yah
Tahoe_Ed Posted at 2015-6-3 21:56
Correct.  I believe that based on the emails that I have received that it will be significantly les ...
has there been any update on when the board with HDMI output will be available?
andy
2015-7-5
Rob88
acollinsdal.yah Posted at 2015-7-6 08:00
andy
The HDMI board is now available . . . . http://store.dji.com/product/phantom-3-hdmi-output-module
2015-7-14
SkySurvey
My HDMI output has flight data......how do I get rid of it?
Cheers
2015-8-26
SpunOne69
I use MiraCast on my smart TV...since The DJI transmitter doesn't use the wifi on my tablet, I connect it to my TV via "screen mirroring"...I can stand in my front yard, and the screen can be seen on my TV.  You are limited by the range of your MiraCast device (mine is about 50 feet)  But hey...it's FREE
2015-8-26
