Ipad mini freezes Mavic 2 Pro
2783 19 2018-12-1
offtheback
Flight distance : 13086942 ft
        Have an Ipad mini software up to date.Flying with M2P and screen freezes.Temp low 40's.I wait a bit and go to home screen+relaunch Go4 app.Still no feed for a bit and usually within a minute comes back.128 GB storage capacity with plenty storage left.Thanks for your help!
2018-12-1
msinger
Flight distance : 228255 ft
Does the same thing happen when you're indoors?
2018-12-1
Kingram
Flight distance : 84085 ft
Which Ipad mini do you have ?
2018-12-1
offtheback
msinger Posted at 12-1 08:35
Not sure.Maybe haven’t had it on long enough
2018-12-1
offtheback
Kingram Posted at 12-1 09:40
2 months old
2018-12-1
Fraggboy
Flight distance : 81401 ft
It’s the video cache. Turn that off and it won’t freeze.  I had to do this on my mini.
2018-12-1
offtheback
Fraggboy Posted at 12-1 12:35
Thanks-will try
2018-12-1
Woe
Flight distance : 4129268 ft
Make sure you don't have any other apps running.
2018-12-1
offtheback
Woe Posted at 12-1 14:48
Did that and only froze once today
2018-12-1
Woe
offtheback Posted at 12-1 16:10
Nice
2018-12-1
msinger
@offtheback, you can find some other tips that should make your iPad run better in this article:
2018-12-1
offtheback
msinger Posted at 12-1 17:33
[view_image]
Thank you Mike!
2018-12-1
Bart B
Flight distance : 878852 ft
Thanks for the tips Mike!
2018-12-1
offtheback
[view_image]
Mike-Only 50% of my settings were bad.Yikes!
2018-12-1
msinger
offtheback Posted at 12-1 20:23
Not bad
2018-12-2
DJI Tony
Hi, sorry for the troubles that it caused. May I know if the issue will occur in the SD Card videos as well? Have you tried to fly your drone in an open area? Changing the mobile device would help to easily isolate the problem in any case that we have a chance to use other devices. Please keep us posted on the latest progress. Thank you for the support.
2018-12-2
Yiliayoung
Actually, iPad screen frozen issue is one of the common problems most Apple users may experience.
Have you checked the battery? Charge your iPad. Or you can restart/force restart the device or restore with iTunes.
One more solution to help fix the potential software bug or glitch is using a Windows or Mac iOS system recovery on computer.
2020-2-17
cony
China
Our iPhone or iPad freezes sometimes, but there are some good methods that can fix it.
1. Force Restart iPad to Fix Frozen iPad
2. Restore Your iPad to Fix iPad Freezes. Get an iOS system recovery software free
3. Clear Up Space to Fix Frozen iPad
4. Resort to Apple Support to Fix Frozen iPad
2020-9-1
Tiana
To fix your iPad freezing, there are usually 4 ways including force restarting iPad, using iPad repair tools, restoring iPad via iTunes and clear iPad storage space.
Force restart iPad ways:
iPad with the Home button (e.g. iPad Air), Hold the On / Off button and the Home button together until the iPad turns off and reboots. Once seeing the Apple logo on the screen, you can let go.
iPad without the Home button (e.g. 2018 iPad Pro), Press and release the Volume Up button, and then do the same to the Volume Down button. Then press and hold the Power button until the device restarts.
2021-3-2
Yeri Tan
I want to give TunesKit iOS System Recovery a like. I used it to fix iPad mini freezes.
2021-5-23
