Uncontrollable spinning at roll axis Z15-GH3
1234Next >
14700 127 2014-11-13
SpreadingWings
fieberbrunn@gma Posted at 2014-12-5 21:27
...ok, but how downgrading to 1.4 ????
email me at info@spreadingwings.com.au
2014-12-5
fieberbrunn
Austria
yuri9999 Posted at 2014-11-18 00:23
Ideal  Z15GH3   GCU .1.4
            A2 v2.4 or remain A2 v2.3 (100% functionally)
downgrade Z15 ...
Please help! I use z15 gh3 and i also Need the Instruktion for downgrade to 1.4!!!!!
Info@mfc.at
2014-12-5
fieberbrunn
Austria
downgrading to gcu 1.4 worked!!! i am very happy. preview works - but:
zenmuse z15 also spiining a little bit in roll and pan axis after initialising - is it a result of unbalancing? or a firmware error again ?
i have GCU 1.4
IMU 1.6
2014-12-6
britboard
Bumping this to the top of the list, any news DJI on this issue please?
Your silence is speaking volumes !!!!!
2014-12-9
canariasdirecto
Flight distance : 257526 ft
yuri9999 Posted at 2014-11-16 23:08
SpreadingWings
You want to help?
give me your email.
Hello, I have the same problem would appreciate all the help you can give me.
thank you very much.
canariasdirecto@hotmail.com
2015-1-25
SpreadingWings
Bumping it up! DJI, when is the fix coming?
2015-1-29
info.clubdrift
chuck@usuavacademy.com
Need to downgrade or DJI needs to fix. We lose video when shutter is triggered
2015-2-7
info.clubdrift
Fixed. Thank you for your assistance
2015-2-7
isikilker.hotma
Turkey
Guys, i need the fix for my ZenmuseGH3. I'm in real trouble with that. Can someone pls help me?  isikilker@hotmail.com
2015-2-16
tyrian869.gmail
Flight distance : 533409 ft
Upgraded GCU worked fine until i tried to rebalanced the gimbal, Clancey@dcinspection.com Please can someone help me!
2015-2-26
tyrian869.gmail
fieberbrunn@gma Posted at 2014-12-6 19:00
zenmuse z15 also spiining a l ...
version firmware GCU 2.4
version firmware IMU 1.8
Not working can someone help? How do i downgrade if i don't have the old  DJI Zenmuse Assistant software? I need someone to E-mail me please...
2015-2-26
CraftyHobo
I am having the same issue. Can someone please email the instructions to fix this issue?
jordan.campbell@whiteknightuas.com
2015-3-3
dennismurry08
Flight distance : 5948264 ft
tyrian869.gmail Posted at 2015-2-27 06:35
Not working can someone help? How do i downgrad ...
What isnt working? Video? Gimbal?
2015-3-4
Mike Koi
does anyone please have a version of 1.4? i am having the same issue and its literally killing me!
a post I've put in several places on the web:
All, I'm having a nightmare. I posted last week about...upon flicking the shutter switch on 14SG the screen goes black on my BP. So to keep flying i can only record video and must turn video on manually before take off and ensure i don't flick the shutter switch or theres a black out.
When hooked up to the assistant, there were 2 updates:
1) IMU 1.8 to 1.12 about Auto calibration, which updated successfully (although now sometimes spins the camera around in a way not seen before)
2) CMU (camera multi unit) from v0.0 to v1.12 with notes describing a shutter problem conflicting with Aux 1, this sounds to me like the fix to the problem I'm having... but this one will not update??
Just constantly getting a pop up telling me the update has failed, please power cycle and try again, and again, and again!
Can anyone with GH3 and GH3 Zenmuse please check what versions your running to see if its the same as mine, or poss send me a version that works, or any other suggestions?
Its killing me now
Thank you
2015-4-4
dennismurry08
Mike Koi Posted at 2015-4-4 21:25
Mike, this is the upgrade for the GH4:
Auto-calibration Function from the current manual:
The auto-calibration function is new to the Z15-GH4 (HD) gimbal. The function is designed to help reduce vibrations that may be caused by gimbal sensor drift.
You can use the auto-calibration function when the following conditions are met:
1. The aircraft is on a flat, level surface.
2. The landing gear is parallel to the aircraft IMU.
3. The gimbal and aircraft initialization is complete and the gimbal is properly connected to the flight control system.
I dont know if this pertains to the GH3..I originally had problems with using the GH4 upgrades on my GH3 and if you scroll up a bit you'll see my issues. I would ping Support and see if you can use this upgrade for the GH3. Otherwise here is the link for the GH3 assistant: http://www.dji.com/product/zenmuse-z15-gh3/download If you want to downgrade to V1.4 just PM me and I'll forward the instructions.
2015-4-5
Mike Koi
Hi Dennis, thanks for the reply to the problem...
Ive totally un-installed the assistant and re-installed it, but its the GH4 one that appears,? and yes if you can forward any instructions to downgrade then ill try that, hopefully it will work! I can't seem to PM you? but my email is
mikened@ me.com
thanks in advance
2015-4-6
dennismurry08
Mike Koi Posted at 2015-4-6 22:57
Ive totally un-installed the assistant and re-inst ...
Ok..I emailed
2015-4-6
gaelarnaud.me
Flight distance : 15449035 ft
Hi Dennis,
please send me your tip. gaelarnaud@me.com
Thanks a lot !
2015-4-7
Juan Nemesio Ma
SpreadingWings
You want to help?
give me your email.
Hi I have the same problem. I appreciate you to send me the solution to my email <canariasdirecto@hotmail.com>
2015-4-7
Juan Nemesio Ma
SpreadingWings
You want to help?
give me your email.
Thank you very much.
2015-4-7
SpreadingWings
2015-4-8
Grisou
Help please I got this problem as well with my zenmuse Z15...
ralph.boelen@gmail.com
2015-4-29
korel
Turkey
can someone help me with too?
korel@live.com
2015-6-23
Dji support 8
korel@live.com Posted at 2015-6-24 00:06
Hi, could you check if the firmware are the latest, IMU1.12, GCU 2.4. These are the newest.
2015-6-23
korel
Turkey
Dji support 8 Posted at 2015-6-24 15:10
Hi, could you check if the firmware are the latest, IMU1.8, GCU 2.4. These are the newest.
Are you sure? Gimbal IMU version is 1.12? Assistant says it is the last one.
2015-6-24
Dji support 8
korel@live.com Posted at 2015-6-24 21:05
After confirmation, the latest version is 1.12.  Is your problem resolved? If no, would appreciate you upload a video to show your problem. this would help me resolve the problem faster.
2015-6-24
1JWJke5XdKMz
I am trying to confirm if this used Z15 gimbal for GH3 is working properly. When I connect it to my WKM with the can-bus cable, mount the GH3 camera with Olympus 12MM lens and then power it all up the gimbal simply spins out of control beating the hell out of my  GH3 camera.  The balance is perfect on all 3 axis but I cannot get past this spinning.  Is it necessary to have ALL of TX connections made from the TX to the gimbal's  GCU in order for the gimbal to settle in or is the Can-bus cable enough just for testing?  As I mentioned in a previous post I cannot get it to connect to my assistant software either in order to flash the gimbal or confirm the FW version.  I am assuming that this is because I have Windows 10 and the gimbal wants to see Windows 7 or 8 from what I have read (?).  Any thoughts on what I can do here?
2016-9-29
dennismurry08
1JWJke5XdKMz Posted at 2016-9-30 02:09
I am trying to confirm if this used Z15 gimbal for GH3 is working properly. When I connect it to my  ...
you need it fully connected...additionally see what version your GCU is...if I remember right it wont function properly on any version over 1.4.
2016-9-30
DJI-Jamie
Flight distance : 112405 ft
To clarify, are you able to connect the WKM to its Assistant Software successfully and not the gimbal?
2016-9-30
fans3d028b13
Flight distance : 40433 ft
Please help, same exact issues now I can not get the GCU to be seen as GH3 only sees it as a GH4.
will@vergonet.net
2017-3-10
ArasT
Sweden
Did you ever solve the spinning issue with your gimbal and S900? I am having the exact same issue today.
2017-3-13
ArasT
Sweden
2017-3-13
ArasT
Sweden
ArasT Posted at 2017-3-13 00:34
I mean the gh3 gimbal on my s900 spins uncontrollably at initialization so I have to unplug the battery to make it stop.
I have not changed any software or firmware. It just went craz
Any ideas would be highly appreciate
2017-3-13
DennisMurry08
ArasT Posted at 2017-3-13 00:38
I'm not at my work but send me your email and I'll forward some instructions to try..
2017-3-14
ArasT
Sweden
DennisMurry08 Posted at 2017-3-14 19:26
Hi Dennis. My email is: jonashund86@gmail.com Thanks!
2017-3-18
DennisMurry08
If you have a GH3 gimbal then the GH4 assistant will not work..you need to get the GH 3 assistant and downgrade the GCU to version 1.4
2017-3-18
ArasT
Sweden
DennisMurry08 Posted at 2017-3-18 10:37
The gimbal is on firmware 1.4. However, since the gimbal started spinning, whenever I connect to the GCU via USB I am not able to upgrade/downgrade the firmware. The assistant app lets me do changes to all the different settings, all except for the upgrade button, if I click upgrade button its just loading for a while and then it says failed.
Also now the last time I powered on the gimbal it doesnt initialize anymore, no more spinning or anything. It just moves a little the first second and then nothing. Its like its off, since there is no power in any motor. However there is video being transmitted since the green led is on under the gimbal and I am getting video to the monitor.
2017-3-18
ArasT
Sweden
I am thinking maybe the firmware was corrupted? Is there a way to HARD reset the firmware like you can do with the DJI A2 by bridge A1 and A2?
2017-3-18
DennisMurry08
ArasT Posted at 2017-3-18 11:47
Do you have the GH3 or GH4 Assistant?
2017-3-25
ArasT
Sweden
DennisMurry08 Posted at 2017-3-25 20:04
I have the GH3 assistant. Do I need to use the GH4 assistant?
2017-3-26
1234Next >
