Waterproof Case
3532 27 2019-7-19
fanseba42e89
Flight distance : 249213 ft
Not sure if anyone has managed to phsically test in the real world yet but on first look I have a couple of potential issues which I am not sure about
The top part rotates which makes me worry about how good the seal is.
Mine was covered in white sandy dust when I got it out of the box, need to really clean the o-ring (which also appears to have a couple of dents which are a worry) as anything, even a hair can render the seal useless.
It's a very tight fit getting the Op into the case, not a bad thing, but trying to get it back out again you literally have to pull it out by the gimbal, not sure how good this is for the unit.
Could do with a lens cap or bag, it's a big area to get scatched, and once scratched will really impact on the quality, could also do with a way to hook on diving filters
I've used underwater cameras for 25 years so had quite a lot of experience, the gopro has been a revelation but I still prefer old school o-rings and grease.
Still hold out high hopes but am serioiusly going to test with some tuees first to ensure it is watertight.
2019-7-19
Paulhd
I agree, it would be nice to have a lens cap. It would of been nice to be able to pull the camera out of the housing by the body. I just about manage to grab at the pan ring area and not the camera.
I have dunked it in water and all good, but that was just a bowl :-))
2019-7-19
El Diabolico
You forgot to mention that the gimbal movement with the UW Mode is severely limited. I have the feeling that the stabilization will not work well (or at all). I guess buying the Osmo Action was a good idea after all...
2019-7-19
fanseba42e89
El Diabolico Posted at 7-19 06:11
Agreed. i'm not expecting much smoothness, for diving it won't be much of a problem as i have honed keeping a camera steady for years, but would have been more useful skiing, jet skiing etc.
2019-7-19
DJI Stephen
Hello and good day. Thank you for reaching out and for sharing these information with us. I hope that you will get the best feedback from the experiences of our valued DJI members who have already used the DJI Osmo Pocket waterproof case. In addition I will forward this thread to the designated DJI department for further development of the DJI Osmo Pocket waterproof case. Have a safe and a happy filming always.
2019-7-19
fanseba42e89
DJI Stephen Posted at 7-19 09:32
Many thanks. As an experienced underwater camera user happy to provide feedback or assist in development.
2019-7-19
DJI Stephen
fanseba42e89 Posted at 7-19 09:54
You are very much welcome. If you have any other concerns or inquiries with DJI. Please feel free to post it here at DJI Forum. We are here to help you and we value your support.
2019-7-19
El Diabolico
fanseba42e89 Posted at 7-19 06:45
Same here, certified in 2002 ( I am a dive master since 2012) but I really see no usage for a gimbal UW if the gimbal doesn’t work. I bought an Osmo Action for that.
Pitty, it looked promising. I guess they had to limit the gimbal’s movement because of the housing’s weird shape while trying to keep costs reasonable. Actually 55€ is very affordable but still, if it doesn’t work what’s the point.
2019-7-19
El Diabolico
2019-7-19
Curt1591
Thailand
El Diabolico Posted at 7-19 16:27
It could just be for those without a GoPro or Action.
2019-7-19
fanseba42e89
El Diabolico Posted at 7-19 16:26
Hoping it will be more useful jet skiing etc
2019-7-20
edwardyyy
any review of this case?
i only find this on youtube:
2019-7-20
El Diabolico
edwardyyy Posted at 7-20 06:07
i only find this on youtube:        https://www.youtube.com/watch?v=O-0USB6xxgQ
If it is real it is indeed very shaky.
2019-7-20
max3.2
DJI Stephen Posted at 7-19 10:19
I suggest to add mode switching when the OP is in the case. E.g. the three tap (selfie) is not used inn UW mode, can we get this to switch from video to slow-mo. And why there is not Hyperlapse in UW mode is not clear to me...Maybe another candidate for a multi-tap to activate and deactivate..
2019-7-22
fanseba42e89
Slow mo is really useful filming underwater. always use it on my Gopro
2019-7-22
RSW
Flight distance : 116736 ft
You have to restrict the gimbal somewhat as you would see obvious distortions as the angle between the lens and the flat port changes. Where the gimbal DOES come in handy is controlling ROLL which can be useful underwater where there is no horizon or flat ground to stand on. And the roll compensation keeps the lens fairly parallel to the port, minimizing distortion.
2019-7-22
vjah
Hi all, not sure if that's help I've just posted a quick video as I was trying the case for the first time. But this is actual footage above and underwater with the case on. And even though I can't swim in my tiny pool I feel like it's not that shaky Will have to see in the ocean with some current.
I'm a bit concerned about how long the seal with last without leaks though... youtube.com/watch?v=KimmDdBc8Mg
2019-7-22
max3.2
fanseba42e89 Posted at 7-22 06:49
I made a thread on this. Please help push it so DJI gets the idea as important!
2019-7-22
DJI Stephen
max3.2 Posted at 7-22 02:15
Hello and good day max3.2. Thank you for reaching out and for sharing your suggestion with us. I will forward these thread and these valued information that you have provided us today to our DJI designated department for further development of DJI. After the evaluation of the engineers, significant suggestions or requests and information will be implemented via the firmware update, app update, etc. For any updates, please stay tuned to the latest news in our DJI official website at www.dji.com or by checking the Release Notes specific for your product. Thank you.
2019-7-22
El Diabolico
RSW Posted at 7-22 07:25
I’ve been diving with UW cameras since 2002 and I’ve used flat and domed ports without any issues. The field of view on the OP is not extreme so a good quality domed cover could be the solution without destroying the stabilization or limiting movement. So far every YouTube video ‘testing’ the OP’s case looks quite shaky.
If you get any domed port for an ultra wide GoPro you get no distortion. I don’t believe DJI isn’t capable of producing this... the main advantage of the OP is the mechanical gimbal. I personally had to buy an Osmo Action for UW activities. I guess Rocksteady will work better than the crippled stabilization on the Pocket.
Time will tell.
2019-7-22
RSW
I ordered this to protect the port on the Osmo case. It should arrive today. I will report back on it. https://www.amazon.com/gp/produc ... 0?ie=UTF8&psc=1
2019-7-23
SuperCurro
Flight distance : 2357828 ft
I have the diving case and test today surfing... The follow mode is super fast so shaking and unusable. I make a test in normal mode and slow follow mode without diving case mode and perfect. You have to be careful with the case limitations but that is all.
The glass is so big that I guess it will scratch the second day, spare parts or a hard surface is welcome.
2019-7-23
RSW
RSW Posted at 7-23 09:15
I ordered this to protect the port on the Osmo case. It should arrive today. I will report back on it. https://www.amazon.com/gp/product/B07MXVLK7L/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
It stretches around the knurled ring for a perfect fit.
2019-7-23
fanseba42e89
Ordered one myself. Looks like it's perfect for the job.
2019-7-24
Paulhd
That is a nice addition and I will have to get one.
I would of been happy to pay £55 for the UW case and have it in the kit already. A lens cap should of been part of this kit without any doubt.
It is like Nikon or Canon sending out lenses without a lens cap. Crazy.
2019-7-24
fanseba42e89
Paulhd Posted at 7-24 01:15
Agreed. it's crazy.
2019-7-24
SuperCurro
ALERT! VERY IMPORTANT!
After yesterday disaster today a try again, when I clossed the cup it didnt fit smooth. I LOST THE SEALING RING!
After a deep search around all the house I found it in the garbage. I could install it again and it works, but the place where you have to fit it is not adecuate at all, is very easy to lose it.
BE VERY CAREFULL WITH THE SEALING RING, if you lose it the dving case is completely unusefull and you will destroy the osmo pocket = 350+50 $€ lost, and the feeling to be stupid.
2019-7-24
Vjah
RSW Posted at 7-23 18:38
Such a great idea, thank you for sharing !
2019-7-25
