how to correct horizon on the SC?
5619 13 2019-7-29
fans589cba4b
Flight distance : 12780633 ft
Noticing all my clips are about 2-4 degrees slanted to the right. Any way to correct on the fly? I'm using the calibration but still uneven horizon.
Thanks
2019-7-29
Andy Mihail
Romania
Following. I have the same problem on SC.
2019-7-31
chefdesetoiles
The same for me, 2° to the right. No way to adjust Ronin SC roll from the app ?
2019-7-31
Moni Johnson
Flight distance : 1375846 ft
I do not have this issue with my Ronin SC but my associate does with his.
2019-7-31
djiuser_6yfM412e0dd0
Poland
I have the same problem :/ Did you do joint angle offset calibration in the app ?
2019-8-4
fans589cba4b
djiuser_6yfM412e0dd0 Posted at 8-4 09:47
i didnt see that as an option in the app.
2019-8-9
fans589cba4b
i'm going to try just adding a shim under the camera.
2019-8-9
doctorpablo
Flight distance : 97418 ft
I've got the same problem! I tried to correct the Joint Angle, but it doesn't solve anything!
2019-8-10
Poland
fans589cba4b Posted at 8-9 20:00
You have to go to settings -> more and hold for a few seconds ,,joint angle"
2019-8-10
Poland
doctorpablo Posted at 8-10 01:57
Unfortunately in my case it also didnt help
I went to dji and they try my camera with their SC gimbal and it kept horizon perfectly so I sent it to service and now waiting for response
2019-8-10
David_61
got the same problem, camera is a bit to much to the right side, needs adjustment  about one degree to the left
2019-11-13
project-mdp
Flight distance : 33671 ft
Same after update firmware!
2019-11-24
ctiptonk
Same problem. You can fix it by opening Create > Joystick in the app and moving the roll axis, but it resets every time you sleep, power cycle, or double-tap the trigger. Super frustrating.
2019-12-3
djiuser_dx5MzJoHb2pN
Latvia
Same issue after update 3° to right
2021-2-18
