JJB*
Flight distance : 12717890 ft
Hi,
At 1m54 you press the RTH button on the RC.
Craft into RTH but could not fight the wind. From 162 meters to 253 meters further away in 20 seconds.
You CX the RTH, but still moving backwards.
At 2m32 lost connection for 470 seconds!! lost conncetion with 55% battery level and connectet again with 9% batterry level. Distance out 441 meter.
Smart battery autolanding 4% batt level, this to land the craft safely from flying height minus 60 meters to ground level.
Nope, its different! Oops, as height is referenced to take off height, beacuse minus value of 60 meters the smart batt took control at such a low value.this because MM thinks it is close to the ground, uh, its lower than start height so smart battery shoud act minus x% batt level (ofcourse not thus 4%...)
Hope the distance craft actual ground is reachable landing with only 4% batt level to start with
Distance away for long time the same, so landingh spot is known.
Landing at : 14.09342200,120.93536300
Hope you can find the MM, guess hard due to many trees there. (if my GE is up to date)
cheers
JJB
