SRP Phantom 3 ND Filters
12Next >
8599 61 2015-6-12
salota8550 This user has been deleted
2015-6-12
DeadWood
I cancelled my order with polar pro and I got them from SRP.
Customer service is absolutely non existent at polar pro, my "shipped a week ago" order is still in the warehouse.
Thanks salota8550   for the info
2015-6-12
FantomDK
Denmark
A cheaper solution to try ND-filters specifically for Phantom 3 www.phantomfilters.com (this is my website).
2015-6-12
2015-6-12
2015-6-12
FantomDK
Denmark
salota8550 Posted at 2015-6-13 13:12
looks nice, did you try them?
Full disclosure - I'm running www.PhantomFilters.com so yes, I've tried them
They work fine and do the job. I've yet to compare with the more expensive solutions. I think it is a good starting point for using ND-filters with the P3. They weigh practically nothing so they don't cause any weight/gimbal-balance problems.
2015-6-12
2015-6-12
FantomDK
Denmark
I can surely imagine it - I fly in such conditions all the time myself!   I love the Golden Hour.
Some time next week I am bringing out an ND16 (1.2) that is very dark (likely too dark for that sunrise lighting but might be good for middle of the day bright sunlight).
If you film straight at the sun like that, there will be zebra-stribes (overexposure) and that is okay. You would have to make the rest of the image completely dark to avoid zebras/overexposure right in the sun. We should not try to use our P3s to film sun-spots or solar-eclipses ;)  What you should do in any case if shooting stills right at the sun is, to shoot brackets and make a HDR-photo out of the frames. I usually shoot all my stills in brackets (mostly 5 brackets) to get maximum quality and freedom to control the lighting in my photo-software (I use Lightroom).
The ND-filters are light and thin enough that you can stack them if you need an extra strong effect. If you already got the Snakeriver, my ND-filters should work with them - were you just put the PhantomFilters ND-filter in side the Snakeriver filter - the same way you would otherwise install them in the standard UV-filter that is attached to the P3 when we get it. You can see installation-photos on the website.
2015-6-12
AssHatModerator
FantomDK Posted at 2015-6-13 13:38
They work fine an ...
What are the filters made of -- are they plastic, glass or gel type?  (And why does one of the photos you used look like there is a scratch on the filter!)
2015-6-20
FantomDK
Denmark
AssHatModerator Posted at 2015-6-21 06:40
What are the filters made of -- are they plastic, glass or gel type?  (And why does one of the pho ...
Polyethylene - "gel". It is a reflection
2015-6-20
martin
Sweden
Mange tak Jakob!
I received your ND´s yesterday quick delivery and will try them soon.
I have ordered Polar´s kit too but like the idea of a simple sollution
and also  good to have a couple of solutions to choose from...
Cheers--Martin in Stockholm
2015-6-21
gil
Flight distance : 1379308 ft
FantomDK Posted at 2015-6-21 08:36
I do like the way these fit inside the lens cover so the added weight is minimal.  However, my concern with gel filters is cleaning them without leaving any scratches and the way they tend to curl.  Do these filters come in any kind of storage container to keep them flat?  (or are they a thicker material that doesn't curl?)
2015-6-21
martin
Sweden
martin@austinso Posted at 2015-6-21 18:02
**** The posts are shielded ****
Why is my reply not visible?
2015-6-22
ljwsteenbergen
Flight distance : 959783 ft
FantomDK Posted at 2015-6-13 09:30
A cheaper solution to try ND-filters specifically for Phantom 3 www.phantomfilters.com (this is my w ...
Hej Hej Fantom,
Just placed my order. Looks to me like a very good and economic solution.
Bert
2015-6-22
gatorone30
Flight distance : 1145489 ft
I got your filters on Saturday and shots some great footage on Sunday. I used the ND 6 and it worked great! It was a bright day and it allowed me to get my frame rates down where they needed to be.
IT is a bitch to get the lens cover off the first time. Thanks for providing an affordable solution!!!
2015-6-22
superdodoz
Flight distance : 118422 ft
I will received my SRP delivery today. If the weather is good, will do some testing and share it with you.
2015-6-22
SULTAN This user has been deleted
2015-6-22
2015-6-22
FantomDK
Denmark
gil Posted at 2015-6-22 01:46
I do like the way these fit inside the lens cover so the added weight is minimal.  However, my con ...
If you make a finger-print on them it is easy enough to clean them gently with a soft cloth.
I deliver them in flat storage pouches that keep them flat and protected.
When installed behind the UV-filter (the front part of the DJI camera that unscrews) they fit nicely between the lens and the UV-filter.
2015-6-22
FantomDK
Denmark
SULTAN Posted at 2015-6-23 07:49
Do you have ND100 filters.
The strongest I currently have is ND16. Which is quite dark - it only lets about 6% of the light thru.
If needed, you can stack the ND-filters for a stronger effect.
2015-6-22
2015-6-22
2015-6-23
ditzlerphoto
Flight distance : 37470 ft
Here are some notes that might help people that want to use ND (Neutral Density) filters.
If you are serious about getting the best video quality from your DJI Phantom 3 then you want to shoot with the best settings. The most professional look is achieved by shooting at a shutter speed that is DOUBLE what the frame rate is.
For example:
1080P/60  = 1/120 second
4k/30 = 1/60 second
Typical settings: please preview with the DJI app and turn off auto-exposure
Bright overcast daylight - 1080P/60 = 3-stop reduction
Bright daylight - 1080P/60 = 4-stop reduction
Bright overcast daylight - 4K/30 = 4-stop reduction
Bright daylight - 4k/30 = 5-stop reduction
Stackable design:
To get 4-stops of reduction simply add the 3-stop filter and a 1-stop filter.
2015-6-23
kev.wardle
Flight distance : 96555 ft
FantomDK Posted at 2015-6-13 14:54
Ordered the 4 filter set 2 days ago.
Hoping they don't take too long to arrive in the UK.
I agree with other comments. These are an affordable alternative to the over priced others.
2015-6-23
cundemaro
Hi! Do you have a polarised filter for the PH3 P? Is it coming soon? That would be really nice!
Thanks
PS: I'm a future buyer for sure (but I need the polarised filter!)
2015-6-26
PhantomRider
FantomDK Posted at 2015-6-23 11:56
The strongest I currently have is ND16. Which is quite dark - it only lets about 6% of the light t ...
Just ordered full set for my P3Pro. Hope to get them soon! (EU)
Thank you in advance!
2015-6-27
wordsaremything
I have the set from Phantomfilters.com and they work perfectly. Now we just need a good polarized option. Hint, hint..
2015-6-27
020667
Flight distance : 14495 ft
Denmark
Hi
Where in Dk are you - is it possible to pick it up.
tak
2015-6-27
JtrJr-UAV Pilot
Flight distance : 4341 ft
ditzlerphoto Posted at 2015-6-23 20:27
If you ar ...
Thanks for the info, This kind of stuff really helps an idiot like me! (Filters are on the way)
Jerry
2015-6-27
azhomecollectio
I need some actual video footage and photo examples before I pull the trigger
2015-6-27
Quadifier
Flight distance : 2664 ft
Just placed my order too.  Thanks...!
2015-6-27
FantomDK
Denmark
wordsaremything Posted at 2015-6-28 04:18
I have the set from Phantomfilters.com and they work perfectly. Now we just need a good polarized  ...
Thank you. A POL (Polarizer) filter is now available!
2015-6-29
ara9112003
Flight distance : 495869 ft
Hello everyone  I have a very Simple and cheap solution Here.
set of 3 Neutral Density Filters
2015-6-29
Inspector_Tim
Flight distance : 35899 ft
Ordered! Thanks
2015-6-29
sns
Ukraine
Hi there,
Ordered phantomfilters set of 4 on 25th, received today (30th). In Ukraine. That's lightning fast, I think. Thanks!
2015-6-30
Kotaix 1
Flight distance : 932228 ft
Chile
Is it posible to put 2 filters together? For example a polarizer filter + a ND8? http://www.phantomfilters.bigcartel.com/product/5-pack-1-polarizer-filter-4-neutral-density-filters-for-dji-phantom-3-professional-advanced
2015-7-4
FantomDK
Denmark
Kotaix 1 Posted at 2015-7-5 08:18
Is it posible to put 2 filters together? For example a polarizer filter + a ND8? http://www.phantomf ...
Yes, absolutely. I combine two filters all the time, usually the Polarizer-filter + ND8 in sunny conditions.
A few days ago on a sunny afternoon, I was shooting 4K 30 fps video and used the POL-filter + the ND8 and in auto the camera would set itself to the optimal 60 shutter speed, 0EV, ISO100.
So I highly recommend doing exactly that. I personally like the POL-filter a lot and combining it with an ND to control the shutter speed is a great idea.
Here is a photo I too with the PhantomFilters.com POL-filter a nice morning at 5.30am:
2015-7-6
Kotaix 1
Chile
FantomDK Posted at 2015-7-7 10:02
Yes, absolutely. I combine two filters all the time, usually the Polarizer-filter + ND8 in sunny co ...
well done!!!! don't you have some footages in youtube with these filters on?
2015-7-7
spiderbot.sb
Well done, FantomDK.  I especially like the 'tips' page on your site.
(There is a typo further down.  Look for 'use use'.)
2015-7-8
Rigworker
Flight distance : 52303 ft
I am about to make an order but I could not see what type of payment you take. Could you elaborate or point me to the correct page of your site?
Thanks.
2015-7-8
12Next >
