USB-C to USB-C connect drone to mac (not working)
19844 19 2020-5-18
mjolsen
So I have most of my stuff now USB-C.   I tried connecting the drone directly to the mac with a USB-C cable (USB-C / USB-C) and no go.   Use any USB-C to Type A and it works fine (with an adapter of course).
I've tried macbook pro USB-C cable as I read in other threads but no go.   Tried four different ones around the house as well as the USB-C/USB-C short that is for the controller to device.
I've read about Device to Host but that doesn't apply in C to C type cables.
Any ideas?
thanks,
mike
2020-5-18
BobWinNV
Flight distance : 284209 ft
Not all USB C to USB C cables are equal.  I use the Cable that came with my iPad Pro 12.9 inch and it works fine.
2020-5-18
mjolsen
BobWinNV Posted at 5-18 17:01
from Drone to Mac or drone controller to iPad?   I have same apple usb-c cable for my iPad pro too and does not connect my MacBook pro to the drone.
2020-5-18
Hotrod in Daytona
Make sure the cable supports Thunderport3
2020-5-18
bjr981s
Flight distance : 139698 ft
I have had no success to date. I have responded by using a USB hub that has a USB 2.0 port and then using that to connect to drone using the supplied DJI cable.
2020-5-18
bjr981s
2020-5-18
dronespilot
Flight distance : 1392995 ft
I ran into the same issue. USB-C to USB-C for Mac seems to work fine with my M2P. But it does not recognize MA2. What I had to do is that I used my Smart Controller USB - USB-C and it worked.
To get DJI Assistant for Mavic to recognize the MA2, I updated the software to the newer version (by downloading it directly DJI website) and used the Smart Controller cable and it worked fine.
2020-5-18
GaryDoug
Flight distance : 1264639 ft
That's the problem with USB-C. It relies entirely on peer-to-peer handshaking instead of hardware configuration. Doesn't always go well.
2020-5-18
monstermac77
I have the same problem here. I'm rather surprised by this. I had a Mavic Air and was able to use my Macbook Pro's USB-C to USB-C charging cable to pull photos off of the drone without even having to pull out the SD card. Now with my Mavic Air 2, this cable doesn't work.
Could this be resolved by a future firmware update on the Mavic Air 2? Would love some input/our feedback forwarded by one of the DJI forum admins.
2020-6-4
ProQuad
Flight distance : 20296870 ft
Same issue here.  I can connect the MA2 remote no problem with the MacBook Pro cable the computer came with but on the quad itself? nope!.  Can not even connect to pull off photos/videos.  Tried the cable (USB-C to USB-C) that came with the package and still a no go.  Is mine broken right out of the box?  I have a Mavic Pro 2 and I have never had any issues.  DJI, you want to commit on this thread, please?  What is the issue?
2020-6-4
djiuser_3hMRmqgxjclf
My USB-C to USB-C would not work on Windows 10, no trigger at all.  I have a USB-C to USB-A adapter that is connected to a USB-A hub built in to my Dell monitor.  When I connect a USB-A to USB-C cable from the hub to the MA2 bingo.  Lights right up.
2020-6-13
Scott7911
Same problem here. My MA2 transfers fine if I use a USB 3 port on my 2018 Mac Mini connected to the MA2 USB-C port with an adapter cable. Files transfer at about 2 GB per minute. If I use a USB-C cable connected directly between the Mac and MA2 , the Mac doesn't even see the MA2.
The Mac has had other USB-C things connected to the same port and data transfers at high speed (40GPS).
I called Apple and they said I should contact DJI
Any Ideas
2020-8-1
fans433a290f
I have the same problem. The supplied USB to USB-C cable works with an USB to USB-C adapter, but if I try to use (multiple) USB-C to USB-C cables, the MA2 does not connect. This seems to be a DJI firmware problem that NEEDS to be fixed.
2020-8-16
outsider
Flight distance : 11263 ft
Turkey
I tried to use the USB-C cable which is using for charging the remote controller and it helped me to solve the issue for my Macbook.
2020-8-16
TropoBone
Japan
New MA2 user in Japan here. Same issue. Tried connecting my MA2 direct to my MacBookPro13,1 (13-inch, Late 2016, Two Thunderbolt 3 ports, macOS Catalina 10.15.6) to download from the 8GB onboard storage. Nothing. The MA2 did not come up in Finder or in Terminal.  I used the Mavic supplied USB-C/USB-C cable, then the MacBook cable, then the cable connecting my USB-C external drive. Them's all DATA cables with USB-C both ends. Nothing. Nada.Luckily I had an older MacBookAir5,2 (13-inch, Mid 2012) running macOS 10.13.6 (High Sierra) in a drawer. Used the USB-A/USB-C cable that came with my Fly More Combo kit. Boom! MA2 onboard 8GB visible as "Untitled" device in Finder. 7.4GB footage downloaded directly to the 'vintage' laptop in 3 minutes.
The problem is not the USB-C cables.
The problem is the USB-C implementation in the Mavic Air 2.
Disappointed.
2016 onward MBP's are H.265 codec and USB-C only.
Pre-2016 Macbooks are H.264 only.
MA2 boasts H.265 as a selling point. How come I gotta dig out an 8 year old laptop with a legacy OS to get my files outta my latest-and-greatest consumer drone?
Huh?
Please fix it, DJI.
2020-8-17
B737ng
Flight distance : 297106 ft
Same problem and I already posted this. Brand new macbook pro and my Air 2 will not connect at all. Its not even recognized by the mac.
This is my second Air2.
The first Air 2 I had ( before it crashed) it would connect to mac no problems, but the new one i received it will not. I suspect this is some firmware issue.
2020-8-17
Bill in Ohio
dronespilot Posted at 2020-5-18 19:10
There is now a DJI Assistant (Consumer Products ) for the Mavic Air 2 and DJI Air 2S.  Update to that for connection to the drone and controller.
Anyone have any specs on the DJI cable for DJI Air 2S or DJI Mavic Air 2?   C 3.0 or 3.1, Generation 2?, Speed of data transfer?
2021-5-2
fansd89471c7
I successfully connected my mini 2 to my macbook using the supplied (short) cable (usb c to usb c). But now on my second try it's not working. Tried swapping cables, ports... nothing works. What's up with this?
2021-6-18
fansd89471c7
fansd89471c7 Posted at 6-18 10:53
Looks like user error. I had the drone off. Works now with the power on...
2021-6-18
djiuser_H3QG5uXP6elY
was having the same problem with a quality usb c to usb c and also the cable that came with my ipad pro 11.  Refreshed firmware on both the drone and remote using the assistant and also checked for updates on the ipad and there was a small one that didnt seem related but updated anyway.  now both wires work no matter which way round.  hope this help as this has been frustrating for me for the last 2 weeks!At first didnt realise to update the remote you have to connect the cable at the bottom of the remote and not the top.
Also have noted that it does take about 10 seconds for the ipad to recognise the remote.
And now its stopped working again!!!
2021-12-14
