Does connecting the battery to the charger prevent the battery fr...
4206 17 2020-6-30
frankymusik
Flight distance : 27841053 ft
Does "short" connection of the battery to the charger prevent the battery from discharging automatically?
When the batteries are fully charged, the automatic discharge starts a few days later to save the batteries, so to extend their lifetime ...
My question:
For example, if the batteries (fully charged two days before) are briefly connected to the Multi Charger on the eve of a planned flight, they will of course not be charged any further (... they are - according to the assumption - still 100% charged).
But is the time retriggered after which this automatic unloading process is started or can it happen that the unloading starts a few hours later, i.e. overnight?
Sometimes you don't want to have to recharge all the batteries immediately before the flight ...
So it would be helpful if you could stop / delay / postpone the discharge process by briefly connecting the batteries to the charger ...
Frank
2020-6-30
InvisibleName 7
Flight distance : 795653 ft
Nope - their intelligent design means that, once fully charged, they stop charging - they don't have a 'trickle charge' function
2020-6-30
Labroides
Flight distance : 9991457 ft
So just recharge till they are half full for storage and top up when you are going to use them.
So it would be helpful if you could stop / delay / postpone the discharge process by briefly connecting the batteries to the charger.
You don't want to leave your batteries sitting fully charged, it's bad for them.
2020-6-30
frankymusik
InvisibleName 7 Posted at 6-30 04:45
... I meant:
Take the batteries out of the charger and store them in the case for 2 days, for example. After that, they still have full capacity ...
What happens if you plug it back into the charger for a minute, maybe? The control LEDs of the batteries remain dark, do not flash ...
Can it still happen that the automatic unloading process then starts anyway, maybe after 6 hours ???
2020-6-30
InvisibleName 7
frankymusik Posted at 6-30 05:07
... I meant:
What Labroides said above
2020-6-30
A J
Flight distance : 13926112 ft
... I meant:
They won't still have full capacity after two days. The MA2 batteries initially auto discharge from 100% - 96% after 24 hours of the recharge completing. And no, you can not recharge the batteries from 96% back to 100% on day 2. Based on what I've seen the batteries need to have depleted to around 90% before you can recharge them.
The discharge cycle then restarts after 5 days from 96% to 60% which takes 2 days to discharge to that level. As advised, it is better to plan your flights and use the fully recharged batteries within one-day of charging them to 100%. The best plan is to fly the drone with 100% down to around 20% then recharge them to 50% on your return (turn off the charger when the third LED begins flashing) then store the battery until the night before you wish to fly again and fully recharge. That way you won't need to rely on the auto discharge anyway whilst keeping the batteries healthy in storage between recharge cycles. It is also not healthy for the battery to be recharged when near full capacity.
TBH - the loss in flight time from taking off with 96% rather than 100% is about a minute but leaving the battery at 100% for 5 days may cause swelling and cell damage in the longer term. So do not expect DJI to change it.
2020-6-30
Rustic17
Flight distance : 2733760 ft
I agree with AJ....but I have heard on other DJI Intelligent batteries that tapping the power button (as in checking the charge) resets the timer for the one day and five day features. I would assume it holds true on MA2 batteries.
2020-6-30
A J
Rustic17 Posted at 6-30 07:20
That is true and worth testing out as does reset the discharge countdown on other batteries I have used on other drones before. Yet to test it on these given that I have not had to rely on the discharge function as yet but a good point to at least try.
2020-6-30
frankymusik
A J Posted at 6-30 05:47
Thank you for the very understandable explanations!
2020-6-30
frankymusik
That sounds very, very interesting.
I definitely have to test that more closely.
I was looking for something like this, a way to prevent automatic discharge at least occasionally ...
2020-6-30
frankymusik
A J Posted at 6-30 07:36
If someone has gained knowledge about it, then we should definitely discuss it!
Yes, it all sounds very interesting, and maybe you can use it (a little) to influence the usability of charged batteries ...
2020-6-30
A J
frankymusik Posted at 6-30 11:07
You're welcome - you'll find that after setting up the drone on day 1 and flying it a few times the batteries will become the biggest thing to maintain.
2020-6-30
A J
frankymusik Posted at 6-30 11:14
Well I happened to fully recharge two MA2 batteries late last night to fly today but it's been raining on and off all day so I didn't fly. I have deliberately pressed the power buttons within the first 24 hours of the charge so I'll put one of them in the drone before flying tomorrow morning and if it's still got a 100% charge after 36 hours then we'll know it works by resetting the countdown If it's got 96% then it hasn't. I'll return to this thread with my findings.
2020-6-30
frankymusik
A J Posted at 6-30 13:36
Thank you for your efforts, already now!
I will also participate in such investigations, of course ...
Store two fully charged batteries for a week, but:
  • At the first one, briefly press the button every day (for example in the evening) ...
  • ... don't do anything with the second one, so just store them "at rest" for 7 days.
2020-6-30
A J
frankymusik Posted at 6-30 22:44
Ok - I put both batteries in the drone and turned them on after pressing the power buttons yesterday evening before the 24 hour discharge started. Both batteries still discharged and are now showing 96% - so pressing the power button on the MA2 batteries, unlike previous models, does not reset the discharge countdown timer - worth a try! And I put one on the charger and as expected, it won't recharge as the current charge level is too high.
2020-7-1
frankymusik
A J Posted at 7-1 00:54
Thank you so much!
Really interesting - and a shame at the same time, at least a little ...
2020-7-1
A J
frankymusik Posted at 7-1 04:43
Thank you so much!
It's not all bad - I still got a 25 minute flight time flying at 400' AGL in a fresh breeze earlier today with it after taking off on 95% and ironically it literally started raining as I was packing up - had I had that extra minute or two from 100% I would have come home with a wet drone!
2020-7-1
DJI Stephen
Hello there Frank. Thank you for reaching out and for the inquiry. In addition to these inquiry. The DJI Mavic Air 2 has an Auto-Discharging function to prevent the battery for swelling, the battery automatically discharges to 96% of the battery level when it is idle for one day and automatically discharges to 60% of the battery level when it is idle for 5 days. It is normal to feel moderate heat being emitted from the battery during the discharging process. For additional reference I will post a list of the intelligent flight battery safety guidelines. Thank you.
2020-7-1
