s1000, lightbridge, wkm. gear ????
1592 6 2014-11-20
gusisin
Simple question I have an s1000, wkm, video and flight control via lightbridge............
How do I make the gear go up ??????
Are the landing gear servos sbus servos ? if so what channel or do I need a servo extender for sbus ?
Someone must have had this issue before....
Gus
2014-11-20
Blade_Strike
Flight distance : 872694 ft
You could use one of the gimbal servo outputs on the wkm. You must turn the gain down to 0. Then use that channel to control the LG. The only other way would to put a decoder in between the Lightbridge and WKM.
2014-11-20
YUHENG
China
We could use iOS APP change the channel of remote control
It support Roll and Throttle on the left
2014-11-21
MichelAngelo
hi, got the same problem!
how can i use F1 an F2 in Naza M V2 with an 8Channel Transmitter?
Cant controll F1 and F2, no matter what i tried...
2014-11-21
Blade_Strike
You have to assign the correct channel to F1 and or f2.
2014-11-21
gusisin
I am flying an s1000 i am using f1 and f2 for motors.
2014-11-24
Blade_Strike
Sorry about that.. The only way around it would be a dbus decoder or upgrade to an a2.
2014-11-24
