Safe transport
1928 11 2015-6-24
spiderbot.sb
Should I keep the foam block that cushions the gimbal?  DJI thought it best to ship the P3 with this foam block.  Should I continue doing so?
Problem is, unlike the rigid plastic piece, this foam block will wear out in a month or two.
Thanks
S
2015-6-24
robvelez
Flight distance : 1057844 ft
I kept mine as it's helpful for transporting. Definitely keep the gimbal clamp but the foam is helpful as well. Mine has worn a bit but helps keep the gimbal in place and doesn't wobble as much even if I do keep it in a nice protective case.
2015-6-24
P3PO
Flight distance : 16083 ft
I just use the provided gimbal lock firmly wedged in place. Sufficient support.
2015-6-24
SULTAN This user has been deleted
2015-6-25
clkilljoy1
Flight distance : 15207 ft
SULTAN Posted at 2015-6-25 21:34
It wont harm keeping it for long transportation.  It takes a second to put it on and to take it off. ...
Ditto...What SULTAN said.
2015-6-25
Phantom Help
Flight distance : 228255 ft
It's a great idea to use the foam block if your Phantom will be sitting on its side. That should prevent the shock absorbers from getting compressed into that odd position.
www.PhantomHelp.com
Find the latest must-haves, fixes, mods, how-tos, guides, and accessories for your Phantom.
Phantoms in stock and ready to ship worldwide! (see availability)
2015-6-25
rbbtebo
Phantom Help Posted at 2015-6-25 23:25
It's a great idea to use the foam block if your Phantom will be sitting on its side. That should pre ...
Unfortunately, I didn't notice where the foam piece goes before I took it off.... I know how to put the plastic gimble lock on.  Could someone snap a pic of where the foam piece goes so I can properly do this?
Many thanks in advance.
2015-6-25
kevinr621
Flight distance : 36427 ft
rbbtebo Posted at 2015-6-26 04:30
Unfortunately, I didn't notice where the foam piece goes before I took it off.... I know how to pu ...
Here you go
2015-6-25
2015-6-25
spiderbot.sb
SULTAN Posted at 2015-6-26 04:52
I have test that but it didn't do a lot.  Still the gimbal damper get compressed.
There is anothe ...
Thanks for this.  I'll look for your post.
I think my original question was not clear.  The foam piece looks like it will wear out.  It is a good idea to use it but what should be done after it wears out and it can not be used?
2015-6-26
2015-6-26
rbbtebo
SULTAN Posted at 2015-6-26 20:35
on YouTube search for "DJI Phantom Unboxing" and you'll see how it was attached.  Anyway it's quit ...
Thank you.  I'll take a look.
2015-7-1
