Ronin 4d hissing sound on play back
3890 14 2022-2-28
djiuser_WMGTThLIXY9Y
Flight distance : 541949 ft
Please help
I’ve got an issue with the audio recording on the ronin 4d
I’m using the Prossd & tried using a rode boom microphone & the standard built in microphone
All I get is the audio but with a hissing interference louder than the audio, I’ve tried it with two different microphones, reduced the db level to 0 but still get the loud hissing
I’ve also changed the recording format but remains the same,  editing on windows 10 pc using Filmora pro
I’ve tried my other cameras and have no issue with sound, tomorrow I’m going to be trialing a different ssd (Sandisk)
Has anyone else had this issue?  Any ideas how to resolve it?
Thanks in advance for any help
2022-2-28
DJI Wanda
Hello, there. We apologize for the inconvenience. The built-in microphone is mainly used for recording and synchronization of video and audio during post-production. If you have higher requirements for audio recording, we recommend you use professional audio equipment and connect it to DJI Ronin 4D.
Alternatively, please try the following steps to reduce the noise during recording with the built-in microphone:
1. Tap "Audio Level" in the bottom-left corner of the High-Bright Main Monitor and adjust the channel gain appropriately.
2. Go to Home > System > - Fan Mode > Low Noise or Rec Low.
2022-2-28
DJI Wanda Posted at 2-28 17:32
I’ve turned the db meter down to -20 & used a boom microphone & put fan noise on low
the white noise has reduced but is still audible but at the same time it’s difficult to hear the audio I wanted to record
What do you suggest doing now?
2022-3-1
DJI Gamora
djiuser_WMGTThLIXY9Y Posted at 3-1 00:22
Hi, there. Could you please tell me the model of the microphone you're using? Besides, if it is convenient, please give us the original file to do a confirmation. You could upload it to the Google Drive/ Dropbox. Thanks.
2022-3-1
I’m using a rode go video mic & also tried comica boom x-u
These including the built in microphones provide severe white noise
Even when the db is turned down you can still hear it also if you turn it down too much you can barely hear what you are trying to record
Can you tell me where the Dropbox/Google drive etc is or I can we transfer it or put in a link for OneDrive?
2022-3-1
DJI Gamora Posted at 3-1 03:24
https://drive.google.com/file/d/1RwB0rzoMmNWks8AGGhmqG43WH7OSqMx9
2022-3-1
fansdf50142f
djiuser_WMGTThLIXY9Y Posted at 3-1 04:55
I tried this and have a different experience.  The built-in mics are noisy, too noisy but sound is louder than the noise. If i connect an external mic almost all noise disappears. Im left with some very slight hiss at 0dB gain. I assume you did choose external mic L etc  and not line level in L in the menu system .
2022-3-8
SamLea
Hello DJI, We just got our DJI Ronin 4D last week.
I am hearing this springing sound whenever I activate this Z-Axis.
I turned off the internal mic and attached a small boom mic and it lessens that spring noise a little but it does not really solve the issue.
any thoughts?
2022-4-6
DJI Wanda
SamLea Posted at 4-6 09:09
Hi, there. Sorry for your inconvenience. May we have a video to hear the sound? Would you please also send us the SN? We will check and forward it to our designated teams for help. Thanks!
2022-4-7
Holla_DC
I'm actually having the same problem. I've noticed that the problem only occurs when the gimbal is actually in the 4d mode when the z-axis is activated. It's a huge dry air static type of sound. I can't figure out a solution for it.
2022-5-6
Sergio Sanchez Suarez
Mexico
I have that problema when the mic is mounted on cera, I think it's getting the sound from the gimbal motors.
What I did was conecting the Boom to a wireless transmitter and the sound is ok
2022-5-10
fans10ff8054
Flight distance : 784970 ft
Do you have to have headphones to hear audio in playback with the ronin 4d? I also have the DJI mic and after recording I can’t hear audio during playback so do you have to have headphones?
2022-8-25
djiuser_vkz5YKJU5I0f
Hi, I seem to have the same problem as you, has your problem been solved? Did dji explain the problem?
2022-10-3
ShaneYegs
Flight distance : 912507 ft
Can confirm, the mini jack has issues. Even TC was acting up.
DJI please fix our cams. I believe it's a board issue.
COntrol of left and right audio bugs out and fails or creates drops.
Another unit didn't have issues with same equipment.
Thanks.
2022-10-5
KillerKingSSS
Mexico
Holla_DC Posted at 5-6 23:10
Thats the sound of the gimbal motors the solution is placing the boom wirelessly on another part of the room. If youre using the remote monitor anthennas  you have to place the lavalier wireless receiver 30cm away or change the radio frequence on the menu to reduce signal noise picked up by the cables.
Or you can bring a sound guy to the shoot. And record audio separately.
2022-10-6
