whyley27
the gps is mounted on the top half of the phantom.. if you put ur hand over the top it blocks the signal.. if you pick it up with ur hand over the top it blocks the signal.. make sure you have no trees around you, this alo interferes with the gps , "sometimes"...
you may have to take it apart to see if you have any damage to the gps .. if your getting the green lights after a while, that to my mind is normal operation of it.. it can take up to 2 mins to get gps fix with 6 sats or more.. if you move it with your hand over the top of it , it will loose the sats, you just have to let it sit there for a while again before you get sat lock again..
do your testing in a wide open field, away from electrical interferance.. ie electric pylons and metal grates on the floor..
if you feel it is still taking a long time to get sat lock.. you will have to inspect the inside of it to see if there is any damage.. if there is.. new ones cost from upwards of 140 pounds (uk).. like 180 dollars etc.
