What’s the difference between the yellow exposure brackets and box
971 7 2022-8-29
mic75
Flight distance : 3799423 ft
Hi, I’ve searched everywhere including the manual and I can’t find a definitive answer as too what’s the difference between the yellow exposure brackets and the yellow box, if I focus with the button it has yellow brackets, but if I touch on the screen I get a yellow box and also when I use the focus button after tap on the screen, sometimes the yellow brackets come back but other times it’s just the small box.
2022-8-29
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. We may need to coordinate this with our designated team for further clarification. We will keep you posted once we have an update. Thank you for your understanding and support.
2022-8-30
mic75
DJI Paladin Posted at 8-30 01:25
Ok thank you
2022-8-30
fateofangel
Flight distance : 1397238 ft
Poland
i think it is exposure lock
2022-8-30
mic75
fateofangel Posted at 8-30 12:37
It’s only exposure lock if you hold your finger there, if you tap on the screen it focuses on that point only.
2022-8-30
fateofangel
Poland
Dirty Bird Posted at 8-30 14:12
Exposure Lock displays a Lock icon in place of the Auto icon in the lower right corner.
good to know than, thx
2022-8-30
mic75
So the small yellow box is for Spot metering to select a focus point, but once you move the drone it normally but not always goes back to the larger yellow brackets which I assume is normal focus mode.
I found limited information in the manual on page 58 but there’s not a lot of details, there’s nothing explaining the different yellow box, brackets or circle when in video mode which I’m assuming is spot metering for video recording.
There needs to be a clear explanation with pictures in the manual describing exactly how to use these different modes.
2022-8-31
DJI Paladin
You are most welcome. Have a nice day ahead!
2022-9-1
