AVATA aircraft tilted in one direction - no straight horizon image
12Next >
8814 61 2022-10-17
MIMAJ6
Flight distance : 371207 ft
Poland
hi guys!
Latley I have some issues with my new brand DJI AVATA and also DJI FPV too...after i updated firmware to the newest my DJI FPV and also new AVATA start looks like this - tilted in one direction...
ALSO even if battery is fully charged - the aircraft is in low power state....
I have concated DJI support but they are helpless
tilted aircraft
tilted aircraft
2022-10-17
Waden
Flight distance : 192661 ft
Switzerland
On ground with motors shut down Avata is in Low Power State . That's the normal state till I startup the motors.
2022-10-17
MIMAJ6
Poland
Waden = thanks, this is usefull info for me...
any thoughts about this tilted thing? u have smth like this in ur avata?
2022-10-17
New2Mini2
Flight distance : 3895528 ft
Normal, it can't stay in place if it doesn't. Wind.
2022-10-17
msaglam86
Flight distance : 90781 ft
Turkey
Low battery state is just a power saving mode. The bent over thing, I just created the same topic without seeing this. Mine is the same. It flies bent over.
2022-10-17
Ross14
Czechia
I'm also "inclined"
2022-10-17
Bob Brown
Flight distance : 4209662 ft
I am going to go with wind perhaps? Seems like logic would have made that answer obvious though... going to think that people are smarter than that.  I would just try calibrating... just calibrate everything that can be... see if that fixes it.
2022-10-17
Waden
Switzerland
MIMAJ6 Posted at 10-17 05:19
No mine is horizontal.
If it’s tilting it must be drifting ! So I would calibrate the IMU.
2022-10-17
Waden
Switzerland
2022-10-17
MIMAJ6
Poland
Ross14 Posted at 10-17 06:59
I'm also "inclined"[Image]
Do you have fixed this issue?
There was no wind during the day….
2022-10-17
MIMAJ6
Poland
Bob Brown Posted at 10-17 07:22
I have calibrated everything….still tilted
2022-10-17
FPVTrendz
Flight distance : 1241020 ft
MIMAJ6 Posted at 10-17 10:32
I have noticed in all of my flights and videos that it's always tilted to the left wind or no wind. Even indoors, it's tilted to the left. I've just come to work with it because I thought it was just me lol. Now that I know others have the same issue, it may be the motors they put on the left or a balance issue with some Avata's. But I have not tried calibrating it so I'm going to try that to see if it fixes mine.
I can however say this when I go into Manual mode, it no longer tilts to the left like that. So with mine, it may be a calibration issue.
Thanks for posting this so I know it's others having the same issue.
2022-10-17
Ross14
Czechia
MIMAJ6 Posted at 10-17 10:31
There was no wind on the day of the photo shoot ...
2022-10-17
RGMGFitness
Flight distance : 233757 ft
Interesting....I've done a ton of flights with my AVATA and the 'ONLY" time it's tilted like that is when the wind is really blowing.  Since your saying there is "NO WIND" and it's hoovering, but still tilted....something is definitely WRONG.
You say everything is 'calibrated' can you be specific on what settings you've calibrated?   Check out page #24 of the DJI Avata User manual.  There is an 'Auto Calibration' of the downward vision system AND there is an 'Advanced Calibration" system as well.  The 'Advanced Calibration' will require using the "DJI Assistant 2" APP.  Hope that helps...
2022-10-17
MIMAJ6
Sweden
I will try the IMU calibration but advanced calibration with dji assistant 2 app wont do...because DJ assistant app cant see pluged-in AVATA to PC WINDOWS ;(
2022-10-17
Waden
Switzerland
Is it drifting or hovering  in place
2022-10-17
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Can you please try to perform the IMU calibration as this will help maintain the stability of the aicraft? Please make that the calibration finishes without any errors and have a test flight. If the issue persists, kindly please provide us a short video showing the aircraft hovering for us to forward it to our designated team to check. Please keep us posted. Thank you.
2022-10-17
MIMAJ6
Poland
Thanks! Today I will check this and send video
2022-10-18
MIMAJ6
Sweden
coming back with content:
good weather - no wind
after IMU calibration
still tilted and no stability hoovering
whats going on?
2022-10-21
Ross14
Czechia
One would say that the tilt is normal
2022-10-21
Nees
Flight distance : 80991 ft
Belgium
tbh, i see no problem, you might not feel any wind,there is always "something". I would say, if you see the tilt in one direction, turn it 180 degrees, see if the tilt changes and is now opposite. You would be surprised how fast a drone would fly away with "no wind" without gps.
2022-10-21
MIMAJ6
Poland
Maybe, maybe not - I have noticed that after updating firmware to support avata my dji fpv drone also have issue with tilted - and before I don’t have such a issues
Tbh, I don’t know - I think I just resend all set with two aircrafts to dji for checking…maybe my Rc remote controller 2 broke…
2022-10-22
Xviews
Flight distance : 229255 ft
Do not understand the problem, does it cause problems in flight or anything else? No then it is not a problem!
2022-10-22
MIMAJ6
Poland
IT is issue for me because when I want fly in sport or normal mode indoor the horizont is tilted so I must in post do additional work to fix it
2022-10-22
Bob Brown
I checked mine over the weekend and I have a slight tilt also, not affecting the recorded videos but I do have a slight tilt depending on which way the wind is coming from.. even a light wind will make it tilt a bit to hold it's GPS position.
2022-10-24
HDPS
Flight distance : 44957 ft
Brazil
I have the same problem and only started after the last update, i calibrated the IMU and Compass and still tilted. I hope DJI will address the pending AVATA issues in the next update
2022-10-24
HDPS
Brazil
Nees Posted at 10-21 11:59
No problem? so if you drive your vehicle with left front and rear tires all flat and vehicle tilted to left...that should be fine for you....
2022-10-24
HDPS
Brazil
Bob Brown Posted at 10-24 10:36
WHY this issue was not present prior last update?, nothing to do with holding GPS or counter lateral windy
2022-10-24
Nees
Sweden
MIMAJ6 Posted at 10-22 01:49
i would love to see in a indoor video as this will give a better representation.
2022-10-24
MIMAJ6
Poland
Nees Posted at 10-24 20:56
Is it funny - because I shown indoor video to dji service support and they told me to show them outdoor because  indoor may have gps disturbance
2022-10-24
djiuser_OdVGAa59RvZF
Flight distance : 8189 ft
My was tilted as well. I managed to hook it to a manual controller and straighten it out. With out that controller it just stays tilted
2022-10-27
MIMAJ6
Poland
Yes, I have rc controller 2 from fpv combo as well but it doesn’t solve the issue. I want fly in n/s mode indoor and the  proper horizon lvl is crucial in this situation, don’t u think so?
2022-10-27
Ryan97459
Flight distance : 680026 ft
I just took my Avata out for a spin in my work parking lot, and it was also tilted at take-off.  I have noticed this over the last few times I flew and today there was no wind. I was hoping there might be an answer to the problem.
2022-11-17
Ryan97459
Ryan97459 Posted at 11-17 16:44
I figured out what was wrong with my Avata.  One of the rubber bushings was not connected to the camera.  I put it back,  tested and it is good as new.
2022-11-17
Spipes Lee
Flight distance : 1111831 ft
MIMAJ6 Posted at 2022-10-27 20:52
Hi there, any updated on the issue? Have you been able to fix it? I’m asking that as I’m experiencing the same issue too.
2023-1-11
Codegit
Flight distance : 141719 ft
South Africa
Ryan97459 Posted at 2022-11-17 23:18
WOW, thanks this was the fix for me too.
2023-1-12
Drey. I
Flight distance : 1757375 ft
It's tilted because it's fighting the wind. (common sense to me)
2023-1-13
BigDaddyReeves
Flight distance : 670003 ft
I had this problem for awhile. Couldn't figure it out. Recently switched to HQ 4 blade props and I'm level again
2023-1-13
Big Fil
Flight distance : 1113484 ft
There has to be some slight air movement that is not being perceived as wind if it's holding it's position in space while hover in normal or sport then there is air movement. Assuming no weird mechanical misalignments if you were to kick into manual mode and be able to visually put the aircraft at perfect level it will drift in a true no wind/air movement scenario.
2023-1-13
djiuser_kvHlfFo8Ep6y
HDPS Posted at 2022-10-24 14:56
Exactly, tilt is unacceptable with the minor wind. I few in 5 km/h wind and my footage looked like it was fighting the hard wind. I have been flying heli's for years and know-how and how much wind should affect something of this size.
https://youtu.be/crgr_mPqkck
2023-3-2
12Next >
