What does this mean ?
1146 7 2015-8-11
BASS 666
any idea what this means ? it comes up on my screen and i have to X out of it to make it go away ...
my Pilot App goes off and then comes on again when it happens ....
2015-8-11
Akael
That is one of the Android processes that is part of the Android OS. If it crashes it restarts all applications running on the device.
When it crashes you shouldn't lose control with the remote, but you will have to reconnect the application, which sometimes requires a reboot of the device.
2015-8-11
BASS 666
Akael Posted at 2015-8-12 02:24
That is one of the Android processes that is part of the Android OS. If it crashes it restarts all a ...
any idea why it happens ????
2015-8-11
Akael
I have noticed it happens significantly less if the device is in airplane mode when you are flying.
I know that sometimes the app seems to be checking Google Play servers to verify the API keys embedded in the Pilot app, and that seems to be when this is occurring.
I am a software developer and quickly looked into the Android logs, but I need to do some more digging to see if there is anything we can do as customers that might lower the chances of this happening.
2015-8-11
AerialLens
I used to get that, too.
Here is what MAY work on your device (while NOT connected in any way to your P3 Controller - this has nothing to do with aircraft)...
Go into SETTINGS on your device;
Find and open APPLICATION MANAGER (may be under General or More tab for your device);
Find Play (or Google Play);
Uncheck Notifications (may require OK from you);
Force Close (may also require OK from you);
Clear Cache
Go back out to Application Manager
Restart Play Store App and close it again normally. You should never have that error again...hopefully.
[NOTE: It is possible that you want to do the "Play Services" app, as well - I don't think so, but cannot remember.]
All this Google Play error stuff is admittedly rather weird, since you're likely flying in AIRPLANE mode without WiFi anyway;  there are many mysteries in an Android phone. :-)
I do NOT guarantee this will work for you, but it did for me, having once had the same problem. I do not THINK there is any harm/risk in trying. Good luck.
Phil
Phantom 3 Advanced
300A Controller
Samsung Tab Pro 8.4 (Android 4.4.2); all unrelated Apps closed, and in Airplane mode
Pilot App 1.2.0 (As of today - hope to have "GO" Soon)
Firmware 1.2.8
2015-8-11
BASS 666
Akael Posted at 2015-8-12 02:50
thank you ...
2015-8-11
BASS 666
AerialLens Posted at 2015-8-12 03:03
Here is what MAY work on your device (while NOT connected in any way to you ...
your set up is the same as mine but im on FW 1.1.9 so I will give it a go ... thank you ....
2015-8-11
greenbean
Flight distance : 84783 ft
BASS 666 Posted at 2015-8-12 03:10
also, you should quit any and all open applications when flying…..the Pilot app is a hog
2015-8-12
