DJI GO - Android - App always on!
3512 15 2015-8-24
tim.erlandsson
Flight distance : 18619 ft
Sweden
Hey!! First, I've got Phantom 3 Pro; Firmware v1.3.20, and a Samsung Galaxy S5 with DJI GO App v2.0.2.
The DJI Go app does not close fully when I press back or even use "Advanced Task Killer". (The recent app menu does not work either)
I can only shut it down with "Force shutdown" in "App handler". This is annoying, my battery drains alot with DJI running in background! More than 50% in half a day in background!!
Because of the app running in background I sometimes hear the speaker shouting out "Welcome to your aircraft, please check your aircraft status before taking off" (something like that).
This happens even when the app is not running, or connected with Remote Control, with the phone in sleepmode aswell (screen off). Woke me last night when I was asleep!
And a question at last, is there any setting in the app to change the streaming quality to the phone (live video feed), cause sometimes it is a bit laggy!? (especially on my surfpad, Galaxy Tab 3, but sometimes on the S5 aswell)
/thanks in advance!
2015-8-24
steve.hajewski
No solution, but I have the same issue with my Galaxy S5 since installing this app.
2015-8-24
kotanali
I also have a GS 5.  You should be able to see which apps you have used recently by pressing the button to the left of the home button.  From there you can close individual apps by pressing the X in the upper right corner of each app the is open or close all by pressing the button in the lower right of the screen. Hope this helps.
2015-8-24
Nemmo
Russia
Two taps on the right soft buttom on your device and the app will be stop.
Download Video quality to device if your use P3 can't be changed
2015-8-24
kmonson
EYE in the SKY
I also have the same problem with a G S5. Could you better explain what you mean by the "right soft buttom".     Thanks    KM
2015-8-25
tim.erlandsson
Sweden
kotanali Posted at 2015-8-25 10:05
I also have a GS 5.  You should be able to see which apps you have used recently by pressing the but ...
I´ve tried that to... force shutdown is the only way that works for me, but it is a bit annoying.
Right soft button must be the "Back" button (on SGS5 it´s on the right side of homebutton) may be diffrerent on other devices.
2015-8-25
Nemmo
Russia
kmonson Posted at 2015-8-25 20:54
EYE in the SKY
I also have the same problem with a G S5. Could you better explain what you mean by t ...
At the bottom of the screen if you slide your finger from the bootom to the center of the screen You can see 3 icons . So the right icon  seems (arrow to the left) is the target  Click it 2times fast as you can and the app will be stoped and closed
2015-8-25
Sheldy
New Zealand
same issue here, randomly starts going off lol rather annoying even when the whole app process is killed. hope there is a fix for it soon! Samsung Galaxy S5 also
2015-8-25
LarryBanks
Sheldy Posted at 2015-8-26 02:42
same issue here, randomly starts going off lol rather annoying even when the whole app process is ki ...
Same issue, Nexus 6.
All kinds of other problems with the app too:
- Random crashes
- Random video corruption
- Failure to connect
2015-8-30
martinunrue
I don't have the problem with battery drain, but I do get the voice announcements at odd times. Even when the app is not running. Really annoying when its the middle of the night. I'm running the app on a Samsung Note 4.
2015-9-1
uptowndisco
Flight distance : 7394987 ft
Same issue Samsung Tab 4 - 7 ,  wondered where the muffled voice was coming from ? app was closed but could hear a muffled voice
"The home point has been updated please check it on the map"  got some funny look in Maccy D's lol
2015-9-1
lookc111
Malaysia
N5 also same issue
2015-9-6
Gelith
Norway
As a owner of P3 Pro, I also got waked up by this, and It's starting at just without me touching the app.
I've noticed that the app is thining that i connected to a P3 Standard, which I don't own at all.
2015-9-8
biglewey
Flight distance : 3530 ft
Same problem here
2015-9-12
biglewey
Oh and app seems to start for no good reason even if I'm not using it. This has left me with a flat battery a couple of times. Any help please
2015-9-12
Quax
biglewey Posted at 2015-9-12 16:19
Oh and app seems to start for no good reason even if I'm not using it. This has left me with a flat  ...
Any news on this?
When i stop DJI GO (Android) it starts up again within minutes.
What is the need this app is permantely up?
What is XGPushService doing?
2016-3-12
