Does nobody balance their props?
12Next >
3691 52 2015-8-31
Bunkx9
Flight distance : 136946 ft
In the RC plane world, a balanced prop(s) is an important basic mod all owners do. (Balancing an EDF fan is vital, bye bye plane)..
A balanced prop is a more efficient prop. And, more importantly,  it reduces the load on the motor and the ESC.  It also cuts down on vibration as well as sound.
Unless I'm missing something, (post/thread/video) it seems many P3 owners aren't doing this?
2015-8-31
rayrokni
Flight distance : 8139875 ft
i havent had the need to, everything flies just great. i change props if there are any signs of wear and tear! if it aint broke dont try to break it!! lol
2015-8-31
jayhkr
I am the same way coming from the same feild of rc planes. I balance mine jist for that added reassurance on my part. Doesn't hirt, amd only takes a few moments a prop!
2015-8-31
Geebax
jayhkr Posted at 2015-9-1 11:19
I am the same way coming from the same feild of rc planes. I balance mine jist for that added reassu ...
Perhaps you might explain how to do it for those who do not know?
2015-8-31
Phantom Help
Flight distance : 228255 ft
For those who have never attempted to balance your props, you'll be quite surprised the first time you place your props on a balancer. Almost all of my DJI props (both sets) were a bit out of balance. When your props are balanced, your motors will be less stressed and your gimbal won't have to work as hard to steady your camera.
My recommendation would be to buy the SpeedyTM prop balancer. It comes packed with everything you need to balance your Phantom 3 props. Here's a complete list of prop balancer or balancing rods that work well with the Phantom 3:
http://www.PhantomHelp.com/#PropsP3
Here's a good video that explains how to balance props. It's showing Inspire 1 props, but the process works with any props.
www.PhantomHelp.com
Find the latest must-haves, fixes, mods, how-tos, guides, and accessories for your Phantom.
Phantoms in stock and ready to ship worldwide! (see availability)
2015-8-31
Bunkx9
rayrokni Posted at 2015-8-31 21:09
i havent had the need to, everything flies just great. i change props if there are any signs of wear ...
If you're good with your set up, great! But ALL new props come way out of balance. Literally, ALL of them.
If you threw a set of balanced props on, you'd be blown away how much more stable and quiet it will be. No the high pitch whiiiiiiiiiiiiiiiiiine.   More precise reactions to inputs, and *likely* a slight increase in flight time.
Not trying to tell anyone what to do, or come off as a turd here, just passing along some knowledge from my RC plane experience.  I recommend all P3 owners try it out.
2015-8-31
rayrokni
Bunkx9@yahoo.co Posted at 2015-8-31 21:30
If you're good with your set up, great! But ALL new props come way out of balance. Literally, ALL  ...
oh no, if its something that would improve things, im all for it. i will get a balancer and see how it goes.
thanks for the advice. will let u know how it went
2015-8-31
rayrokni
Phantom Help Posted at 2015-8-31 21:25
For those who have never attempted to balance your props, you'll be quite surprised the first time y ...
thanks, just ordered the speedy balancer as recommended.
2015-8-31
Phantom Help
rayrokni, awesome. You won't be disappointed. I've been using that prop balancer with all of my Phantoms.
www.PhantomHelp.com
2015-8-31
rayrokni
Phantom Help Posted at 2015-8-31 22:14
rayrokni, awesome. You won't be disappointed. I've been using that prop balancer with all of my Phan ...
what grain sand paper should i get. i imagine i should have a coarse and a fine or more?
thx
2015-8-31
Bunkx9
rayrokni Posted at 2015-8-31 22:15
thx
I would go with a 1500 grit.
2015-8-31
rayrokni
Bunkx9@yahoo.co Posted at 2015-8-31 22:26
so just the one grit then?
2015-8-31
Bunkx9
Then finish with a 3000
2015-8-31
Bunkx9
rayrokni Posted at 2015-8-31 22:26
1500 to start, smooth with 3000. Just like wet sanding a car's clear coat.
2015-8-31
rayrokni
ok 1500 to start and finish with 3000. now gotta see where to find that here near me, as i dont think home depot would have that high a grit
2015-8-31
Rigworker
Flight distance : 52303 ft
I did mine. I found they were quite close right out of the box. Removing the raised lock icon and arrow was all any needed. Used a DuBro balancer with the optional threaded shaft. I tried it without the threaded shaft as shown on a video but that was definitely not a reliable method IMHO.
2015-8-31
Bunkx9
rayrokni Posted at 2015-8-31 22:28
ok 1500 to start and finish with 3000. now gotta see where to find that here near me, as i dont th ...
Any autozone or auto supply business will likely have it.
2015-8-31
rayrokni
Rigworker Posted at 2015-8-31 22:29
I did mine. I found they were quite close right out of the box. Removing the raised lock icon and ar ...
ok thanks for the advice. i already ordered the speedy one mentioned above, will give it a go.
thx
2015-8-31
rayrokni
Bunkx9@yahoo.co Posted at 2015-8-31 22:30
great will try tomorrow and see.
thx again
2015-8-31
Phantom Help
rayrokni, I don't use sand paper since it permanently alters the props. Instead, I place a small piece of clear Scotch tape on the bottom of the light side of the prop. If it's still not balanced, I add another small piece of tape -- or remove the first piece and add a larger piece.
www.PhantomHelp.com
2015-8-31
Bunkx9
rayrokni Posted at 2015-8-31 22:32
thx again
PS, don't sand anything on the top of the each prop, only the inner bottom, closest to the hub where it's thick. Bad advice by the other guy.
2015-8-31
rayrokni
Phantom Help Posted at 2015-8-31 22:35
rayrokni, I don't use sand paper since it permanently alters the props. Instead, I place a small pie ...
do u mean the lighter side? cuz if i add weight to the heavy half of the prop, isnt it gonna get heavier?
2015-8-31
Bunkx9
Respectfully, the whole point of balancing a prop IS to permanently alter it. The tape method is a band-aid to the problem.
2015-8-31
rayrokni
Bunkx9@yahoo.co Posted at 2015-8-31 22:41
PS, don't sand anything on the top of the each prop, only the inner bottom, closest to the hub wh ...
got it, will do. i may try the tape method first as i have a heavy hand, there may be nothing left of the prop. or i ll try the sanding method on an older set that i dont use
thx
2015-8-31
Rigworker
Bunkx9@yahoo.co Posted at 2015-8-31 20:41
What Guy? Didn't see anyone saying to sand the tops. Good advice though.
2015-8-31
Phantom Help
rayrokni Posted at 2015-8-31 22:41
do u mean the lighter side? cuz if i add weight to the heavy half of the prop, isnt it gonna get h ...
Correct. Sorry about that
www.PhantomHelp.com
2015-8-31
toddf.perkins
Which balancing rod do you guys recommend?
2015-8-31
toddf.perkins
toddf.perkins@g Posted at 2015-8-31 21:59
Are there some rods that are better than others, or are they all the same?
2015-8-31
Phantom Help
toddf.perkins, any of the rods at the link below will work. The important part is to make sure the Phantom 3 props thread onto it. And, the props will fit anything listed there.
www.PhantomHelp.com
2015-8-31
thomaseoday
Never would have known this, thank you
2015-8-31
michael.tristra
Flight distance : 769042 ft
Everyone of my alleged 'balanced' DJI props were out of balance when I measured them, some quite a bit. I used a dubro balacer and a balancing rod with some tape. Now they are all spot on.
2015-8-31
Bobcat90
Flight distance : 2517654 ft
Taiwan
Phantom Help Posted at 2015-9-1 10:35
I am sure sanding an unbalanced prop is one way to go.  I use scotch tape, too.
2015-8-31
toddf.perkins
Bobcat90 Posted at 2015-8-31 23:20
So.. Sanding, or tape. What does everyone think?
2015-8-31
damian
Thanks for the tip!
2015-9-1
astrostar
toddf.perkins@g Posted at 2015-9-1 05:44
I use the DuBro balancer and small pieces of tape. If you over sand and take too much off you'll have to then sand the other side and if you take too much off that ....
I purchased a balancing rod off ebay rather than use the standard rod which came with the DuBro and found that the props balanced with the DuBro rod needed to be re-balanced with the ebay rod which was designed specifically for the Phantom 3 props.
2015-9-1
Bunkx9
toddf.perkins@g Posted at 2015-9-1 12:44
I prefer sanding, 1500 or 3000 grit.
IF you use tape, use electrical tape. Stick it to the MID/INNER TOP TRAILING EDGE of the prop.
2015-9-1
aburkefl
Flight distance : 78612 ft
That was my only complaint - and a small one at that - about the DuBro balancer. To balance the Phantom 3 props, you *must* have their special threaded shaft - and it does not come with the "standard order" balancer package. When I saw I needed the threaded shaft, I called the company. They were very polite, but I had to spend extra to buy the threaded shaft. I personally think that if they're advertising it works with the Phantom 3, even if they have to raise the price, they should include the shaft.
For those new to the world of balancing props, many, many RC plane props are NOT threaded and the mounting hole goes all the way through the prop. The threaded, self-tightening props are not yet the same kind of standard we're starting to see in quads.
2015-9-1
aburkefl
Another commonly used technique is to quickly wipe a dab of super glue along one side of the props.
My preference is for the tape. Despite the rpm of the props, the tape tends to stay on there very well.
The two obvious schools of thought: (1) remove weight from the heavy side by sanding it gently or (2) add some weight - very slowly and very lightly to the light side.
2015-9-1
aburkefl
The tape method has been used by RC plane guys for years. Works fine.
As I wrote in another part of this thread, there are two schools of thought:
(1) add weight to the lighter side
(2) remove weight from the heavier side.
The beauty of the tape technique is that if you put too much on, you can remove some. If you sand too much away OR SAND AWAY IN THE WRONG SPOT! - it's much harder to correct.
2015-9-1
ed.weibe
Flight distance : 40056 ft
Can I mail my P3 and props to someone and have them balance it for me and send it back?
thanks in advance
2015-9-1
12Next >
