Phantom 3 Firmware 1.4.0010 - App Support Thread
1234567
43605 250 2015-9-7
ericholder
Why are all of these firmware updates occurring? I've had my DJI for five months and am already on update #5 which completely freaked out my transmitter and craft. The drone loudly beeps in a loud and obnoxious tone while the LED indicator alternates madly between green and red. I will not respond to anything. I've tried to reboot the update, connect via the App, it's very confused. Further, the transmitter won't acknowledge the update and just sulks on red. This is really a downer give how easy V2 was to own and operate. what is going on? does anyone know?
2015-12-6
kenneth
Flyhigh7887 Posted at 2015-9-7 06:40
i have to say, this is the 1st update that i am a bit weary of being the first to jump on. i have do ...
i have 2 P3s. they are different
2015-12-7
Mohammad Zaerni
Iran
1#
Hello
I got Phantom 3 Professional Update
Phantom I got off at the wrong time update
I turned again and began to hoot intense and long
After a few minutes the horn stopped and the lights were green
However, an error log file
========== 2014.01.01 00:00:13 remo-con disconnect======
Packet: P3X_FW_V01.04.0010.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:12 remo-con disconnect======
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2015.11.17 22:20:58 =====================
Result: Abort.
========== 2015.11.17 22:29:24 =====================
Result: Abort.
========== 2015.11.17 22:30:50 =====================
Result: Abort.
========== 2015.11.17 22:36:01 =====================
Result: Abort.
========== 2015.11.18 10:06:08 =====================
Result: Abort.
Result: Abort.
Result: Abort.
========== 2015.11.18 10:48:02 =====================
Result: Abort.
========== 2015.11.18 10:49:54 =====================
Result: Abort.
========== 2015.11.18 10:51:10 =====================
Result: Abort.
Result: Abort.
Result: Abort.
========== 2015.11.22 00:16:17 =====================
Result: Abort.
========== 2015.11.22 00:27:00 =====================
Result: Abort.
========== 2015.12.07 23:12:23 =====================
Packet: P3X_FW_V01.05.0030.bin
Upgrading ...
========== 2014.01.01 00:00:11 remo-con disconnect======
Upgrading ...
Upgrading ...
Result: Success.
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
========== 2014.01.01 00:00:20 remo-con disconnect======
Packet: P3X_FW_V01.03.0020.bin
Result: Abort.
The current firmware does not support downgrade. Use a different version of firmware to downgrade the target version.
========== 2014.01.01 00:05:40 remo-con disconnect======
Result: Abort.
Result: Abort.
Result: Abort.
****    Phantom and remote connection has been disconnected
And remote and not connected Bird
2015-12-7
whelliot1
I have been trying to update to 1.5.003 is this the same thing? For some reason my P3 doesn't update. I followed your instruction step by step I don't  know what to do. Any ideas?
2015-12-13
lperry17
I've been reading through all your blogs and they are awesome.  I've tried over and over to update version 1.6 on my Phanton 3 Advanced Aircraft.  I am using a Galaxy S5 with the right version, have been told to enable USB logging and reporting.  I'm still getting errors and my cannot see my camera either.  This is the latest hidden error log, does it ring a bell to you?
[00644494]Version checking[1]...
[00024422]========== remo-con disconnect. boot(15) ============
[00024475]Packet [C:\P3S_FW_V01.06.0040.bin] detected, card sn [0x28539bff].
[00024533]Packet upgrade start...
[00024598]Packet checking...
[00024655]Packet vlink 01.06.0040 <-> 01.05.0030.
[00024747]Done.
[00024806]Version checking[1]...
[00037368][03 05][00] device not detected.
[00049928][03 06][00] device not detected.
[00049995][04 00][00] v1.41.0.0 -> v1.41.0.0
[00062560][11 00][00] device not detected.
[00075119][12 00][00] device not detected.
[00087685][12 01][00] device not detected.
[00100239][12 02][00] device not detected.
[00112793][12 03][00] device not detected.
[00135357][15 00][00] device not detected.
[00147914][17 00][00] device not detected.
[00160468][17 01][00] device not detected.
[00173143][19 00][00] device not detected.
[00173196][01 00][00] v1.22.4095 -> v1.22.4095
[00173258][01 01][00] v1.22.4095 -> v1.22.4095
[00185816][09 00][00] device not detected.
[00185872]Packet upgrade failed at version checking.
2015-12-28
Adminescriba
Flight distance : 34980 ft
Honduras
Can i post?
2016-4-1
Adminescriba
Honduras
Hello sploodge!! I hear you are the man, well income here looking for help, im desperate! Stoped using the drone for a few months, the dji gonapp updated by itself so i have the lastest app and the latest software on the aircraft, my problem came to light when it was time to update the firmware on the remote controller, for just a few seconds i was able to enter camera view and see the warning that i needed to update the rc to 1.3.20. And i have been trying and trying i feel i bricked my remote controller, be advised i control gimbal and am able to fly the drone, i just cant, i cannot enter camera view for live feed or perform imu calibration, i cannot enter camera view. I cannot upgrade using memory stick method or via cable method. How doni find out which version fw my rc has?
2016-4-1
Adminescriba
Honduras
Sorry! More details are, phantom 3 professional, mininipad, ios 9.3.1 updated today, i updated thibking that was the fix
2016-4-1
Old Geezer
Flight distance : 23691 ft
Why resurrect an ancient thread?  I just wasted 20 minutes reading through it thinking it referred to the latest update from end of March 2016 !!!
Grumpy Old Geezer
2016-4-2
njulianfderas
Hey there I'm newbie in the forum I have this problem,do anybody know what's De module 07 00
2016-10-7
njulianfderas
sploodge Posted at 2015-9-7 08:31
Seems not on IOS at the moment... Android is out.
Hi a quick question ,I know is kind of difficult to guess what the module codes from the logs but I have a p3s crashed but I already fixed,double check. Connection wires and everything seen normal
I have already use android's devices(iphone6+,ipad mini 2,LG tablet,iiphone 5s and a note 3)no way to bet it upgraded or downgrade checking logs the module 0700(00) not detected....is the only one that makes the firmware fails, what could be. ...help will be so appreciate
2016-10-7
1234567
