JJB*
Flight distance : 12260774 ft
Hi,
Had a look at your flightlog too.
Take with zero satellites, no HomePoint set ofcourse at your start position.
First part your Mini4Pro using the vision to fly nicely....
At 19.7s in flight 14 sats + a '3' for GPS signal quality, now the 30 meter height limit is off.
At 21s HomePoint set during flight, above a tennis court, see picture.
Rest of flight normal.
At 3m35s a disconnect, flying at 71 meter baro height and 1165 meter away from HomePoint.
Disconnect for 26 secs, so in the RTH mode.
Now at 105 meter, distance out 1114 meter, next records drone is slowly descending to 90 meter...normal for a Mini4Pro.
But after few seconds in RTH again a disconnect.
Disconnect for almost 3 minutes....
So in this 3 minutes it did fly to your HomePoint ofcourse, i mean why not ? this is normal drone behaviour!
Flying to HP about in 130 seconds + landing from 110 meter to zero = aproxx 40 secsonds
So my guess it just landed at Homepoint, last record shows motor off and high drone pitch and roll values, so it did not landed smoothly.
As not all records in the log are written at the same time....i am not surprised to see GoHome for the last records with distance still 1113.9 and Height zero.Baro height is zero`d at rotors off.
GPS rest of the flight solid 30 sats with good quality.
cheers
JJB
