Making the Action Cam 4 swivel at the end of my selfie stick?
1752 34 3-20 11:21
djiuser_2iaELOCP6YtP
Belgium
Hi all,
I was wondering if there was any product out there that I could attach to the end of my selfie stick so I could make my action cam swivel around so it can either face me or turn the other way.
I know of the spivo stick, but that one makes a disturbing noise and makes the camera turn super fast, resulting in a a very blurry transistion... Is there any other stick or stick extention piece that would allow me to do this?
Thanks a lot,
Kind regards,
Peter
3-20 11:21
Fishycomics
George  Non-stop I watched used one, gonna have to follow  this topic. maybe  find a way to rig one up
3-20 12:45
osmonauta
Hungary
Are you looking for a motorized swivel or just a manual one?
3-20 13:55
Belgium
osmonauta Posted at 3-20 13:55
Hi, Thanks for answering.
I'm eager to explore both options. But it would be cool if it could swivel more than just once.
3-20 14:30
osmonauta
Hungary
Well, manual swivel implies that you have to turn the camera. In which case you can turn it as many times as you wanted to :-)
Seeing the motorized option, I'm not sure if you wanna go with the manual way. I have this 360 swivel ball mount:
https://www.aliexpress.com/item/1005003961035776.html
You can attach that to the selfie stick with this:
https://www.aliexpress.com/item/1005004062895857.html
And of course you put this one at the top of the 360 mount and you attach the DJI magnetic adapter to this:
https://www.aliexpress.com/item/32896947943.html
Yeah, I know, it's quite a setup so this might not be the one you looking for, but you can tilt, swivel, pan, turn the camera whichever direction you want at the end of the selfie stick - albeit you have to do it manually each time you want to change it.
3-20 16:52
Bashy
Flight distance : 2354357 ft
djiuser_2iaELOCP6YtP Posted at 3-20 14:30
Something like the TELESIN 360° Rotating Intelligent Followup AI Face Recognition Buliti REL
3-20 17:51
lutzmix
Bashy Posted at 3-20 17:51
Telesin ai face trekking
or use a gimbal
you can use the hohem remote with hohem isteady4
3-21 00:02
Dale 68
Flight distance : 338468 ft
Now that looks like a good bit of kit.
3-21 00:22
Fishycomics
the Obsbot is a lot smoother people say over the telesin auto tracker but way more expensive that both ar light weight contenders
this is  a swival has about 8 positions
3-21 03:06
lutzmix
Fishycomics Posted at 3-21 03:06
the new is  Rotatable to any positionn no more 45⁰ steps
pan 360⁰. tilt 180⁰
3-21 03:39
Fishycomics
lutzmix Posted at 3-21 03:39
pan 360⁰. tilt 180⁰
love to see a link to the Obsbot, because II putthat on my wish list, has to get modded  as its was only a smartphone  unit
3-21 03:55
Belgium
Thanks for all the replies. I'd like a link to the Obsbot solution too
3-21 10:56
Belgium
On the Hohem iSteady: it does not list the osmo action cam 4 as compatible... Also, does it allow me to rotate it manually? Thanks a lot!!!
3-21 11:59
Fishycomics
hohem Isteady pro 4
3-21 12:11
Belgium
That Hohem gimbal looks promising, but will it fit my osmo action cam 4 inside of its DJI case and with a Ulanzi cold shoe mount attached? I use it to attach the DJI mic 2 receiver sometimes...
Thanks a lot!!!
3-21 12:36
johansenfoto
Flight distance : 1173379 ft
Norway
djiuser_2iaELOCP6YtP Posted at 3-21 12:36
Thanks a lot!!!
No it doesn't.
Else it would be too big for most action cameras.
3-21 16:17
lutzmix
not possible
max payload 170gr
with cold shoe and receiver out off balance.
You need a bigger Gimbal: Hohem M6 ore better MT2
https://youtube.com/shorts/XUBIyFGtioI?si=iQ_RcWlnPdVYTZ1X
https://youtube.com/shorts/Xt5I0YTV46U?si=sSNjYJlJO5cE3tc0
https://youtube.com/shorts/Katq0hJnpYY?si=t9zpSNlU24yda0OF
light receiver J12 or smallrig are ok
use the bt mic
selfiestick a  mono pod up to 2m
3-22 00:30
lutzmix
lutzmix Posted at 3-22 00:30
not possible
max payload 170gr
[Image]
An Osmo pocket 3 or Feiyutech pocket 3 on the DJI selfie stick is easier
3-22 04:12
Belgium
How would I use the Hohem M6 with my Osmo Action Cam 4? The M6 is for smartphones, or is there a way to detach the smartphone clamp and attach an action cam clamp?
Thanks a lot!
Peter
3-22 04:35
lutzmix
3-22 09:24
lutzmix
djiuser_2iaELOCP6YtP Posted at 3-22 04:35
Thanks a lot!
Peter
hohem mt2
3-22 09:57
Belgium
Thanks a lot everyone! I'll go for the iSteady 4pro Kit, as that has a stick, a remote and is splashproof
3-22 10:35
lutzmix
more multifunktional is the m6
3-22 10:54
Belgium
I know that it is more versatile, but it is not splashproof. But if this one doesn't fill my needs, I guess I'll go for the MT2 instead of the M6. But thanks for all the advice, it is highly appreciated
3-22 14:18
lutzmix
djiuser_2iaELOCP6YtP Posted at 3-22 14:18
add the tiny hohem remote
https://youtube.com/shorts/JQI--Tvx_uY?si=f0RLErKGbh2_Ve1E
remote4 : more than splashproof
https://youtube.com/shorts/7Is6L_AnJls?si=6gK-qEICCqPAbHVs
3-22 20:08
Belgium
Thanks! I did I chose the "kit" version which has the remote. I also have the DJI remote
3-23 02:17
lutzmix
Thanks a lot!!!
you can try  a small cable strap & bt mic and remote
this is 20mm, I think  5-10mm are ok
remote:
https://youtube.com/shorts/Katq0hJnpYY?si=DIfvv2L2d0jhNw3C
3-27 00:10
Fishycomics
Velco can be narrowed   remember, you're blocking  the touch screen.
3-27 03:55
lutzmix
I can use my phone
3-27 04:32
Choking Smokers
Thailand
Some very impressive... and complicated solutions here. Here's how I deal with the problem using the selfie stick that comes with the Action 4 Adventure Kit and can be purchased seperately. I find it's very easy to tighten the screwpin so that it holds the Action 4 and it's mount pretty firmly in place but still allows me to easily tilt it. So if the Action 4 is pointing forward and I want to turn it to film myself I just reach out, bend it down and then flip the selfie stick over...it takes about 2 seconds. I have a YouTube channel in which I do a lot of hiking in jungles and scrambling up mountains and it's always worked, I've never had it where it's just too loose and moves itself while filming.
3-28 00:50
lutzmix
Choking Smokers Posted at 3-28 00:50
I like that too
add the Telesin tripod (new version ) and a remote
or with 90 cm Telesin power bank
https://youtube.com/shorts/AUI8ytByBoI?si=uOsQpjW5CMBiLgX_
3-28 04:09
Choking Smokers
Thailand
lutzmix Posted at 3-28 04:09
I like that too
I like the way that Telesin tripod folds back on itself. You say it's a new model, what's the exact product name/number? Thanks
3-28 23:53
lutzmix
Foto is the old one
this is the new with extension rod
Telesin Aluminium tripod
you can use it with Hohem MT2
3-29 02:10
Choking Smokers
Thailand
lutzmix Posted at 3-29 02:10
Foto is the old one
Thanks. I bought Telesin aluminium selfie stick that comes with the tripod that folds back on itself (I much prefer having a tripod permanently attached as I need it often, the foldback design is such a neat feature.)
I prefer the DJI selfie stick tbh  as it's tighter and longer but the Telesin tripod section is great and fits directly onto the DJI stick so I best of both worlds solution (looks like you did the same). It also came with an adjustable clip that adds a screw mount which I've also transfered over to the DJI stick.
4-1 20:02
lutzmix
isteady pro 4 and Hohem remote works well
4-3 23:17
