ratephi
Switzerland
Yesterday I purchased my first. Once back home I plugged the battery that came with it just to find out that the battery would not charge (no blinking or anything, just dead). Fortunately I had a second battery which seems to work fine.
Once the second battery was charged I tried to test the drone (it was late at night and I was at home so I just wanted to test if everything was fine, load the software on my Android device and update the firmware). The update of the drone went fine (as confirmed by the .txt. file produced at the end of the procedure), the update of the firmware on remote would not start (I assumed the version of the firmware was already the most recent).
Problem is that, when I finally tried to connect the remote to the drone, nothing happens. I don't see any option to access the camera mode from the Android app, hence cannot even reset the connection between remote and drone. TO make the whole experience a bit more annoying, given the missing link to the remote, I have no way to set it back to travel mode...
Anything that I can try to reactivate the communication between remote and drone?
Many thanks in advance for your support with this.
