DJI ESC Assistant v1.4 E310 ESC 420 2312E Support
6540 14 2015-10-1
Mad_Angler1
Flight distance : 2741657 ft
The 420 ESC's now supports the 800 and 960 KV 2312E Motors as well as the older 2212 Motors
2015.09.29
Overview
DJI ESC Assistant software version updated to: v1.4 ESC firmware version updated to: v1.3
Major Updates
The2312E(800KVor960KV) and 2212 motors are now supported by the DJI ESC Assistant.
The E310’s ESC (420S) firmware is now compatible with the 2312E (800KV or 960KV) and
2212 motors.
Notice
Be sure to update the DJI ESC Assistant software to the latest version before updating the E310 ESC firmware or configuring the 2312E (800KV or 960KV) or 2212 motors.
http://www.dji.com/product/e310/download
2015-10-1
billdunow
I have had serious problems after updating my E310 system on my  F550 with the NAZA-M V2. After the 420 ESCs update to 1.3a the aircraft will barely  hover at full throttle. The LEDs turn yellow meaning the motors are at full throttle. They never turned yellow with the 1.2 firmware. The aircraft is very unstable now. I have tried to work with the gain setting with no luck. I wish there was a way to go back to 1.2.
2015-11-20
rich
Flight distance : 197680 ft
Ive got the same problem now. Did you get to the bottom of it? Nightmare!
2015-12-31
maicoalvim
Flight distance : 167999 ft
Brazil
billdunow@gmail Posted at 2015-11-21 02:20
I have had serious problems after updating my E310 system on my  F550 with the NAZA-M V2. After the ...
Were you able to solve your problem friend? I'm also having the same problem.
2016-1-21
prwells
Can we get a solution for this DJI?
2016-2-12
DJI-Amy
Please try to update the latest firmware. If you still have the same issue then reply me here.
2016-2-16
DJI-Amy
prwells@gmail.c Posted at 2016-2-12 19:01
2016-2-16
DJI-Amy
rich@marshalls- Posted at 2015-12-31 21:08
2016-2-16
prwells
DJI-Amy Posted at 2016-2-16 21:48
The current firmware still shows as 1.3a ???  That is the same version with the issues.
What is going on???
2016-2-21
ars68
Flight distance : 21654 ft
prwells@gmail.c Posted at 2016-2-22 00:27
What is go ...
You could solve the problem ??
2016-2-26
DJI-Ken
Flight distance : 1515312 ft
What is go ...
The firmware was updated but the version stayed the same.
2016-2-26
gn0m
Flight distance : 975476 ft
Poland
DJI-Amy Posted at 2016-2-17 05:49
Hi,
I have the same issue :/
E310 & ESC - after instal it, I'm download soft and update my brand new system to 1.3a (ESC assistant 1.4) :|
motors work in idle to 50% throttle stick, when I up to 51% or more, all motors has going very quickly to max rpm and LEDs turn to yellow (meaning the motors are at full throttle).
my specs:
F550 frame
Naza M V1 up to V2 link via S.BUS2 to futaba R7008SB
Zenmuse H4-3D
iOSD mini
immersionRC 600mW
2016-6-2
DJI-Adela
gn0m@op.pl Posted at 2016-6-3 07:56
Hi,
E310 & ESC - after instal it, I'm download soft and update my brand  ...
Hello.
According to your description, your ESC should be working normally. No worry about that.
Thanks.
2016-6-3
gn0m
Poland
Hi,
it works great
Thanks DJI-Adela.
2016-7-1
fans92886b2d
Brazil
dji lightbridge of my S900, does not communicate with air and ground system, someone has idea
this problem?
2018-1-30
