Cetaman
Flight distance : 2528264 ft
Aloha remltr,
". . . is it a good practice to point one antenna straight ahead and the other at a 45 degree angle?"
Hmm, what if one of the antennae is for video and one is for flight control? I do plan to test this with a blind of trees and an antennae range extender. The blind is 600 feet away and blocks a flat operational area up at 75 feet above me and still within walking distance. I have already lost signal when I attempted to land my P3 up there (for fun) and high-tailed it out-a-there like a bad puppy when that happened. But, since then, this forum has said repeatedly that the video signal goes first, which may have been my case and now I want to try it again.
This is where the range extender comes in to play. Instead of the two range extenders recommended for the P3P, I plan to use one that I can hold in the proper configuration against the antennae with my hand. Trusting the advice of this forum, I plan to land my P3 at the flats, with or without an associate with a cell phone present up there, and then see which one of the antennae improves the video. If there is no difference, then both antennae are for flight control and video downlink. If there is a difference then it will tell me which antennae works for which. Either way the result of the test should provide me with video for the lift-off.
The nice thing about the flats and the blinding trees is that there is just enough to be disruptive, but not enough to destroy. And if all else fails, I just have to retrieve the P3 from a flat unobstructed area and figure out what went wrong. I hope!
Aloha and Drone On! |
