How to mount the gimbal mounting plate of Zenmuse X5
23849 16 2015-10-13
DJI-Tim
In this video we will show you how to install the gimbal mounting plate for the Zenmuse X5 and X5R on the Inspire 1 platform
2015-10-13
Machoman
Flight distance : 1036959 ft
Austria
This is a useful video. Thanks.
Questions:
1. Can the X3 cam also used on this mounting plate?
2. Is the X5 mounting plate itself better then the X3 ones regarding vibrations?
3. What is the weight difference of the X3 and X5 mounting plate?
2015-10-14
Hterag
Flight distance : 961978 ft
China
I'd also like to know if the X3 can be used with it as I wouldn't like to have to switch the mounting plate each time... Though, I've a feeling I wouldn't actually change it again after installing the X5.
2015-10-14
DJI-Tim
Machoman Posted at 2015-10-15 01:01
Questions:
1. X3 camera can be usen on X5 mounting plate
2. X5 mounting plate has  better vibration absorption performance.
3. Difference between X3 and X5 mounting plates is not big enough to influence the flight at all
2015-10-14
Hterag
China
DJI-Tim Posted at 2015-10-15 14:27
2. X5 mounting plate has  better vibration absorptio ...
Does the X5 mounting plate have to be bought separately to the X5 camera or is it included in the kit?
2015-10-15
DJI-BladeStrike
Flight distance : 872694 ft
Hterag Posted at 2015-10-15 07:26
Does the X5 mounting plate have to be bought separately to the X5 camera or is it included in the  ...
Correct it's separate from the camera. The vibration plate kit does include the leg extensions though.
2015-10-15
mikegil
Flight distance : 32730 ft
are the leg extensions going to make a difference with fitting in the inspire case?
Mike
2015-10-15
OISHI
Flight distance : 2456043 ft
Please put this video in the X5 / videos section as well . This one will save calls into support and possibly repairs.
This video is superior to that one...well done!
2015-10-15
REDBARON
OISHI Posted at 2015-10-15 21:54
Please put this video in the X5 / videos section as well . This one will save calls into support and ...
User name change!
2015-10-15
rodger
Flight distance : 20145135 ft
Thanks Tim, good info.
2015-10-24
remltr
I believe a step is missing in this video.
It shows removing the dampers from the gimbal in order to detach the gimbal from the craft, but not completing the step of removing the dampers from the craft.
The next scene shows them removed from the craft, but does not mention that as a step.
Do I have that correct?
My X5 is arriving tomorrow and I want to make sure I do the uninstall and install correctly.
Thank you.
2015-10-25
remltr
So I answered my own question by doing the install.
I love how this video fails to show the installer fumbling with these little screws in order to line them up and hold the parts together while doing so.
One thing that needs to be mentioned is that the screw driver needs to be 2.0 mm not 2.5 mm as mentioned in the video. Anyone having a 2.5 mm will probably have a 2.0 mm. Just trying to save someone a little time and frustration in preparation.
I know I'm making a little fun of the video, but it really is a well done and very helpful.
2015-10-26
vonbaron1
Flight distance : 42014 ft
Install the dampers on my I1 with the X3 and went well.  As stated above, the front old dampers have to be removed.  Other then that, the video was right on and helped.
2015-11-1
mani
Flight distance : 2233904 ft
Romania
Can someone confirm if Inspire with Zenmuse x5 vibration board will fit in the original DJI case ? My Zenmuse X5 just arrived and I would like to install it, but I need to know if it will fit in the orginal case, as my landing mode X5 case will arrive in around 2 weeks.
2015-11-25
noaches232
DJI-Tim Posted at 2015-10-15 01:27
YES!!! I was deciding whether to get a phantom 3 professional or the Inspire 1. Done! I'm getting the Inspire 1.
2016-1-29
Alan CCTV
it isnt a 2.5 mm hexagon screwdiver its a  2mm
2017-9-7
fanscd1faf6f
Flight distance : 19587 ft
Can someone let me know the exact size of the 4 screws?
Can't find that info anywhere.
I'm guessing M2 x 6.
Would like to get it right.
Thanks in advance for the help.
2020-10-28
